Wheel Offset?
Old May 9, 2014 | 08:13 PM
Chace's Avatar
Wheel Offset?
I'm buying a staggered set of wheels for my 2014 TL FWD. The wheel sizes are front 20x8.5 +35 offset and rear 20X10 with a +25 or + 37 offset. Im not sure with which offset to go with on the rear. By the way I was thinking of going with these size tires: front 245/35/20 and rear 255/35/20. The main thing that I don't want to happen is if I decide to lower it in the future and if Im riding passengers in the rear, I don't want it to rub. At the moment I don't plan on lowering it. And Im trying to stay away from rolling the fenders. What do you guys think?
Old May 9, 2014 | 09:10 PM
carbonTSEX's Avatar
The Original Shawdy
Id go with rear 20x10 +37 if you don't want some work to do. Even at those specs gonna be pushing it close. You'll probably need a roll in the rear if you decide to go lower but the fronts will be good. Tire size is good though.
Old May 9, 2014 | 10:55 PM
scotty2hotty's Avatar
You will be sunk in and safe with those offsets. Even the +25. It's less than 1/2" difference.
Old May 9, 2014 | 11:08 PM
potmilkz's Avatar
go with +37 on the safe side.. +12 will require you to roll your fenders down and require a slight camber.
Feb 25, 2020 09:57 AM
KB1_EJ6
Aug 28, 2016 08:25 AM
BreezyTL
Jul 26, 2016 12:52 PM
nuldabz
Sep 3, 2015 05:49 PM
bailey24
Aug 31, 2015 05:38 PM
