WeatherTech digital floor mats problem.
Anyone having problems with it? With the temperatures around -15 C for the last few weeks floor mats feel like wooden boards ,they slide forward and back around 1.5",the sides are curled up and deformed(especially drivers side)...there is nothing holding them in place(they don't have any holes in them to hook on floor locks, only 2 bumps that "fit" over the locks ).
I just spend 45 min cleaning all the crystalized salt from floor fabric liner all around the mat...This is a statement from their website :
Will our FloorLiners warp or curl up under extreme temperatures?
No, the material remains flexible even in extreme temperatures.
(yeah sure.....BS)
I am I the only one with those problems???
Its driving me crazy...
What about these? Anyone have them....they look good ,maybe better that WeatherTech...
http://www.ebay.com/itm/360770803031...84.m1423.l2649
(yeah sure.....BS)
(yeah sure.....BS)
(yeah sure.....BS)
This is the first winter with my WeatherTechs I have noticed them to be looser than desired in extremely cold temps - we have had several weeks in a row here below 10F, often below zero. Mine slide forward and back, at times interfering with the clutch pedal which can be annoying. My fix is to put adhesive backed velcro hooks on the backside of the mat to hold it in place.
Not ideal, but in extreme temperatures I am pretty confident most materials would have the same issue.
6G TLX-S
As a comparison, are the factory rubber mats holding up flexible, under the same cold temperatures ?
Hey guys just noticed this thread if it's -15 and it does that I could imagine how it would be where I live where it averages -30 to -50 I'm thinking of buying a set but I've seen them in other cars where it's hard as a wooden floor
Let me kno how it works out for you guys
Yes....those are extreme temperatures ....(Damn...)
no problems with mine. Although, it's in the mid 20's during the day and at night a bit colder. However, my car is kept in a garage at night where it really doesn't get colder than 40f. Anyway, even if I keep my car outside at work and it drops to 10f, I have no issues with curling or anything you've described.
mine are doing just fine, no slip at all, i dont even have them locked in like they are supposed to be as they are just on top of my factory mats with the extreme temps of the midwest
2012 AcuraTL Adv
arek1200, I noticed the exact same problems with my weathertech liner on a 2012 TL. Don't drive the car much and is parked in garage all the time, hence did not notice this problem until I went on a long trip from Austin TX to San Francisco CA. The liner is stiff and warped and will not anchor into the lock, thus causing the slipping problem which affects the gas pedal operation.
Don't know what the solution is but sure is dissappointing when you pay around $200 for floor liners. Any suggestions or ideas are welcome.
Yes, that's the same problem I am dealing with....I don't know what the solution is but it looks like the mat hardens, stiffens,and deforms as it gets older.... Or maybe its just a manufacturing defect...
Yes, I will contact them...
I got really pissed off one morning (-24 C that day, car parked outside)when I was done clearing snow off of the windows, getting inside and my foot slipped with the mat pushing it and hitting accelerator pedal reving it up to red line with almost frozen engine..
I was foaming at the mouth....
Keeping TL until 2029
I have not had an issue with the mats. I have had them for 2 years. The first year was mild and this year was has been brutal. I have an automatic car and the foot rest area (lower left) should hold it in place. You need to make sure the the inside rail (closest to center tunnel) for the seat doesn't push the mat forward. I have to check and tuck it under the seat as driver 1 and driver 2 seat settings are different. I.e. moves back further. Also, if you start the warm up process before clearing the car can help.
im talking about the oem all weather mats, there are holes that can clip into the floor board, and then you turn the little clip which wont allow them to move. I dont use them, i just toss them on top of my factory mats
why would you do that? Just pull out the originals when you use these. I don't even think the lock would be long enough to extend through both matts
2012 AcuraTL Adv
My liners are exactly like the one arek1200 has with the dome and no holes for the twist lock.
I spoke to WeatherTech and they said I had to go through the dealer that I bought the liners from. What a pain, went back almost 2 years on my email and found the order. Called Autoaccessories.com and talked to a lady there. She was like, I don't know if there's anything we can do cause it was so long ago. I told her that I bought the liners from them less than 2 years ago, warranty is for 10 years, and WeatherTech adviced me that I had to go thru them for any warranty issues.
Finally, she said for me to send her pictures of the liner and my car with my order number and see what they can do. I'm like what is the picture of the liner and the car going to do for the slipping problem that I'm experiencing.
Anyways, I sent the pictures and order number and now keeping my fingers crossed to see if I can get a satisfactory resolution.
I am 100% for getting dealers to throw in all weather floor mats for free. I've got the Acura factory all-weather floor mats and they lock in place perfectly, don't move, don't curl, and are still supple at -15F. After reading this thread, I think I will always stick with factory over Weather Tech should I ever not be able to negotiate for them.
are you sure the warranty is for 10 years?
That is what they have on WeatherTech.ca :
WeatherTech® FloorLiner™ is guaranteed against faulty materials and workmanship for a period of three years from the date of purchase. Exclusions to this warranty are wear due to severe abrasive conditions and chemical contamination, such as spilled gasoline, bleach, etc.
Now if only there was a way to get people in the back seat to keep mud off the back of the front seats. Being leather, it does clean up nicely.
The difference between the weathertech digital fit versus the OEM all weather ones is that weathertechs are liners. They are designed to act like a bowl and all the edges are lifted to protect and stop rain, snow, dirt from getting onto the actual carpet of your car. Occasionally during harsh winter storms, you'd need to empty it out since water does build up. You'll notice in the spring after you remove your OEM mats that salt catches on all around the edge of your floor. The weathertechs do not do that.
As for me, I've had my weathertechs for about 3 weeks already and I've had no issues with it curling or anything and that's in -30c Canadian weather plus I park my car outdoors. I also have the lock in style that twists and I've had no issues with it slipping anywhere.
What is the level of protection offered and how does it differ? People are complaining the weather techs get hard and curl. I have had the OEM ones for several years and use them year round. I have a lot of muddy boots in my car in the summer, and snow and ski boots in the winter and my carpet looks as good as it did when I bought the car. I think they do an amazing job. In fact, I had a half full bottle of washer fluid break on the floor of the passengers seat recently and the OEM mat contained the spill and I was able to lift it our without spilling any into the car.
rrbruinfan (02-25-2014)
These are OEM style floor mats. They're flat and have no lift. There are minor bumps that channel the water around.
![](http://handa-accessories.com/tl/tlmatslrg.jpg)
This is the WeatherTech Digitalfit Liner. No flimsy rubber. All edges lifted to provide complete channeling and no overspill.
![](http://www.tacomaworld.com/forum/attachments/2nd-gen-tacoma-marketplace/112157d1313432679-weathertech-digital-fit-floor-liners-black-weathertechs.jpg)
2012 AcuraTL Adv
arek1200, you are correct regarding 3 year warranty. The floor mats have a 10 year warranty. It seems like we are the only unfortunate ones with the dome instead of the hole in the liner. The instructions did mention twisting to lock which I couldn't figure out - now I know why.
Hopefully, WeatherTech will come thru and send me one with the hole.
2012 AcuraTL Adv
arek1200, just got a response from autoaccessories.com that WeatherTech is going to ship me the redesigned liner.
Good Morning,
The front set for this vehicle has been redesigned, Weathertech is sending you a
replacement for the front set only. Please allow 7-10 business days for delivery.
Have a great day!
Diane
Returns Dept
Good Morning,
Have a great day!
Diane
Returns Dept
2012 AcuraTL Adv
potmilkz, you need to go thru the dealer you bought liner from. I indicated that this was a safety hazard because the liner would slip over the accelerator pedal and impede my driving.
You really shouldn't have any problems getting a replacement, if you have your receipt, even without a receipt I would imagine they would replace the liner due defective design which may cause accidents.
Be firm and cause a stink if they give you a hard time.
Good luck.
Good luck.
