Vinyl tips/tricks?
d0wN sHiFtInG
Vinyl tips/tricks?
Hey guys, just got my smoke vinyl in today. Was planning on doing all my lights this weekend. Does anyone have any tips/tricks they would care to share?, i've never done this before lol
I have a heat gun, rapid tac, several different squeegees and an xacto knife. I have a 2x4 piece of the vinyl, i think that should be enough for all the lights granted i don't fcuk some sh!t up.
Ive done mine a couple of times, dont be afraid to pull up different parts of the vinyl even if it sits on the tail light perfectly. Dont be too worried about air bubbles they'll eventually go away (if its bubbles galore re-do it)
Dont be scared to pull it off, make sure you dont over heat the plastic because itll burn or tear in half when your stretching it.
TotheMax (07-19-2013)
for taillights,, work from the middle going out.. make sure when you cut the vinyl.. you give all sides about half an inch of extra vinyl.. just incase you need to wrap around..
I had a pro do my red vinyl tails, but i was curious so i watched him do it.
You should be fine. Good luck
d0wN sHiFtInG
I appreciate the advice! I will try and post a few pics, i'm not doing anything to crazy. The vinyl is very light smoke, i hope it's barely noticeable however giving the rear that ever so slight "mod" especially after shaving the badges off.
also.. please take the tailight out before you do it.. makes going around the edges much easier.. and its really not that hard to take the tailights out.. i can do it in less than 5 mins.. all you have to do is peel back the trunk lining and remove 3 bolts.
d0wN sHiFtInG
I just might do that, depends on how hard it is. I do want it to look legit, I ordered all the tools required to get into the crevices but if they don't work out well i'll take the light out. I know it's not hard, i've done it before
it is just easier and cleaner to do it with the lights off the car...
this way you dont get rapid tac liquid all over the paint of your car..
d0wN sHiFtInG
d0wN sHiFtInG
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Either i'm gonna get it professionally done or i'll go the plasti dip route
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Thanks for your help & advice!
What does this thread have to do with the 4G TL?
Could you post some pics of the project?
OP, did you buy the pre-cut kit or a standard sheet?
For those who have done their tails what would you recommend? If the pre-cut, does it wrap around the edges?
Also, why do you need the rapid tac if the vinyl has adhesive backing?
Thanks in advance.
Thanks in advance.
d0wN sHiFtInG
I failed miserably so best of luck with this lol... i might give it another go though
ucf_bronco (08-01-2013)
I'm surprised you found the sheet to be cheaper. I measured the tail light last night and figured 12" x 32" sheet would be needed for each (though a 9" x 30" might suffice). Even the 9" x 30" is $30 each though and I found the pre-cut set for $55.
Hopefully someone can chime in on the fitment of the pre-cut. I would think it's gotta be sized to go around the edges.
I watched a guy do my grille a while back. It looked pretty difficult (and the results were far from perfect) but I'd imagine the tail light is much easier, so I'm gonna take a stab at it.
ive attempted the tail lights twice.. and both of the times... it did wrap.. but it had soo much bubbles that i couldnt get rid of.. so i said fuck it.. and diy painted the tail lights..
now its nice and glossy
Ah, decisions decisions...
I ended up buying a standard sheet as it was way cheaper than the pre-cut. I also figured the pre-cut wouln't wrap around the edges. And yes, rapid tac is recommended even with the adhesive backing.
ucf_bronco (08-02-2013)
$80, he had the red vinyl on hand, took him about 45 minutes. I had the same guy do my carbon xp tint a few months before. I feel like the stuff he put on was thicker than the lamin x only from feeling the difference in the reverse cutout, but they might be the same. It has been really durable through washings and snow etc.
oyayjoe
09-12-2015 04:40 PM
