Those with LED fog lights...
Old 03-19-2015, 01:40 AM
andrewcjduong's Avatar
So I'm looking for a set of LED fog lights to replace my current yellow halogens. I know some people are rocking VLED or other brands but I found this set...
Morimoto XB LED headlight bulbs CREE
Does anyone have any input on these? Or do they happen to match the headlights? Seems like the output is really good and the price is amazing plus they're a sponsor so we get a discount.
Old 03-19-2015, 05:51 AM
arpypat's Avatar
Found a thread on this forum
https://acurazine.com/forums/perform...source-913270/
Old 03-19-2015, 08:24 AM
BDoggPrelude's Avatar
The Morimoto Type-S XB LED fogs are a direct replacement for the 12+ TL. I have them and they are pretty nice.
si1point6 (03-20-2015)
Old 03-19-2015, 08:33 AM
Received 8,692 Likes on 6,706 Posts
Get the direct replacement instead of the bulb! The optics will be infinitely better because it's the entire housing that's custom-created by TRS for the 3 LEDs inside. 10/10 recommend. If you see the price difference as an issue, you can sell off your OEM fog light housings and recoup the costs .
Old 03-19-2015, 08:44 AM
acupower's Avatar
It's worth mentioning that the direct replacements are only for the 2012-14 TLs.
Old 03-19-2015, 12:01 PM
HeartTLs's Avatar
Link please.
Old 03-19-2015, 01:42 PM
8th Gear
ICPGr8Milenko's Avatar
Originally Posted by HeartTLs
Link please.
Morimoto XB LED Fog lights
Pretty sure these are them.
Old 03-19-2015, 02:31 PM
HeartTLs's Avatar
Ty.
Old 03-19-2015, 04:51 PM
As mentioned above, the direct replacement is only for the 12+. The 09-11 which is what I have has an oval housing of some sort or something. No one has them? I've been up and down on threads looking for a demo.
Old 03-19-2015, 06:08 PM
shurik74's Avatar
^^^ mine is 2011 and ran into the same issue when I wanted them ;(
Old 03-19-2015, 11:07 PM
kcarr91's Avatar
think i just found my next mod...
Old 03-20-2015, 04:22 AM
real_mckoy's Avatar
I know endlessrpm has the led fogs for sale, im not sure if they are the exact same.. Maybe you should partner up with someone in customer service to see if they are the same so you can go from there. Did you ask customer service at the retrofit source?
Old 03-20-2015, 10:50 AM
HeartTLs's Avatar
Has anyone installed these? I have morimoto low beams with matching fogs and the output on both are better than anything else I see on the road. How does the LED fogs compare to the HID's?
Old 03-20-2015, 11:58 AM
I have the Morimoto LED fogs in my TL and the light output is significantly better than the HID's I put in our 07 TL's fogs. They match the low beams almost perfectly.
Attachment 102701
HeartTLs (03-20-2015)
Old 03-20-2015, 12:26 PM
ucf_bronco's Avatar
^^^Is that just the LED bulb or the aftermarket housing as well?
Old 03-20-2015, 12:44 PM
HeartTLs's Avatar
Did you have Morimoto HID fogs as well or other brand?
Old 03-20-2015, 06:55 PM
AndrewTRS was able to confirm that it would not fit a 09-11 and that only 2012+ had it because it was similar to TSX's fogs and the demand for 09-11 wasn't as high as 2012+ TL's and TSX's
Old 03-20-2015, 07:25 PM
It's the entire housing. The Morimoto XB LED Type-S Fogs. It produces a nice flat cutoff line similar to the low beams.
No, they aren't Morimoto HID kits.
Old 03-20-2015, 07:59 PM
Jerry"O"'s Avatar
Very nice! very nice! Can't beat the morimotos xb led and the v-leds V3 Triton switchbacks. They are the best in business period!!!
BDoggPrelude (03-20-2015)
Old 03-20-2015, 10:16 PM
Jerry, you should post your pictures showing the cutoff lines of the fogs under the low beams.
Old 03-20-2015, 11:14 PM
Jerry"O"'s Avatar
Ok here are the cut off lines of the new morimoto xb leds. Low beam are the original Osram CBI 5500K from Germany, no mode to low beam lenses. Enjoy..............
Old thread https://acurazine.com/forums/fourth-...type-s-915221/
Attached Thumbnails Those with LED fog lights...-top-osram-cbi-5500k-bottom-morimoto-xb-led-5000k.jpg   Those with LED fog lights...-side-view-pic-2.jpg
The following 2 users liked this post by Jerry"O":
BDoggPrelude (03-21-2015), Drei (03-21-2015)
Old 03-21-2015, 12:27 PM
Just wish someone could post LED fog lights that use OEM housing...
Old 03-21-2015, 01:52 PM
Drei's Avatar
Those cut off lines look SO clean Jerry O
Sucks that those housings won't fit 09-11 TL's
Avenger411
10-11-2015 03:53 PM
rockyboy
09-29-2015 12:05 AM
rhdune16
09-28-2015 11:31 AM
Ratheruneeq
09-28-2015 07:41 AM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: Those with LED fog lights...
