Smacked A Deer
Yep. No way to avoid hitting it. The Doe got up like it was nothing, "That's all you got..Ha Ha Ha.. "and took off. Lots of deer where I live. The Doe would had made it accross had it not tripped.
6G TLX-S
$900 in front-end damage after hitting a deer is considered not expensive, when compared to the $2500 front-end damage after a RLX hits a smallish rabbit.
https://acurazine.com/forums/3g-rlx-2013-412/jack-rabbit-versus-rlx-897277/
No pix. Car in Bodyshop. The front fascia paint was cracked and has deer hair within the crack, so it's being repainted. Busted Left Turn/Parking Light Lens, broken mounting brackets, cracked Passenger Side Fog Light, part of Splash Shield missing on bottom of fascia.
The HIDs took a whack, as they are out of alignment so the Lens once removed will be inspected for any damage. The damage does not look bad but a little love tap cost a little. The fascia is out of alignment, along with headlight, so Fit and Trim will have to be performed, along with headlght adjustment.
