SH-AWD diff fluid...
Old 04-21-2011, 08:23 AM
vinnier6's Avatar
so i am comming up on 10k miles, and havent seen a6 or b6 calling for a diff fluid change....
who has or had theirs changed, and at what miliage...the manual says at 7500 then every 15k miles after that...
we need a diy with pic...anyone?
Old 04-21-2011, 09:20 AM
Qwikhas's Avatar
In for DIY as well.
Old 04-21-2011, 09:32 AM
vinnier6's Avatar
Originally Posted by Qwikhas
In for DIY as well.
come on guys..anyone have this done yet, what miliage? dealer cost, diy or what...
Old 04-21-2011, 10:09 AM
2010 TL AWD 6MT: New King
docboy's Avatar
My first B16 (rear diff change) showed up at around 15,000 miles.
Stealership wanted $200 just for the rear diff. I had it changed at a local garage I trusted. Had oil change, tire rotation, and rear diff for $99 (plus the so-called "inspection").
Old 04-21-2011, 10:36 AM
vinnier6's Avatar
my dealer, goodson acura dfw, wanted 130 plus tax to do just the diff....i told her for that price i would be doing it myself...just waiting for someone to post up a diy, or atlest some pic of which bolts are drain and which are fill, i took a quick peak under, and can see what looks like one of them, but will wait for someone who has done it to chime in....
plan on doing it at 10k, with my next oil change...next week sometime
word
Strosek (07-05-2013)
Old 04-22-2011, 07:18 AM
vinnier6's Avatar
called david mcdavid in plano, they will do it for 75 bucks...still want and probably will do it myself...
Old 04-22-2011, 01:37 PM
lji
lji's Avatar
Seems Acura changed the Differential Fluid to be used in 2011+ models. The 2011 cars now use DPSF fluid instead of the ATF-Z1 rear differential fluid. I saw this in a Service Bulletin and it mentions that the differential case in 2011+ models are marked DPSF. Seems this was a running change and some early 2011 production TL's are still marked for the ATF-Z1 fluid, but dealers are advised to use the DPSF fluid (caramel in color vs pink for the ATF-Z1) on 2011+ models. Does anyone know what the pros/cons are to using DPSF over ATF-Z1? Will the new fluid work with the 2009-2010 TL's?
Old 04-22-2011, 01:47 PM
silver01cltypes's Avatar
thats because they have a new trans fluid and atf-z1 will no longer be available when what ever is in honda's stock is gone.The new trans fluid is suppose to be synthetic.Iam sure that the dpsf fluid will work fine in older models too.eventually atf-z1 will not be available.so this fluid should be the new recommended for shawd rear diffs
Old 04-22-2011, 04:57 PM
mightl's Avatar
Does change the type of diff oil require a flush or it will be a flush regardless? or it does not matter?
Old 04-23-2011, 08:36 AM
SHAWD10's Avatar
The following text is directly from the October 2010 Acura Service News Bulletin:
New All-Wheel Drive Fluid
(DPSF) for SH-AWD
Acura parts stock has a new SH-AWD rear differential fluid available. It’’s Acura All-Wheel Drive Fluid (DPSF), and it replaces ATF-Z1. It’’s been specifically formulated to withstand the extreme conditions in the AWD differential, offering better protection and greater longevity.
DPSF is the factory fill for all ’’11 Acura models with SH-AWD, as well as some ’’10 models, and should be used in ’’10 and earlier models that call for ATF-Z1 or DPSF. However, ’’01-06 MDXs will still use VTM-4 differential fluid.
Models that are factory-filled with DPSF have DPSF stamped on the rear differential assembly. The fluid is also clear instead of pink. If you need to top off the diff fluid and DPSF isn’’t available, go ahead and use ATF-Z1; it’’s OK in a pinch.
DPSF is available in 1-quart bottles (P/N08200-9007A).
Old 04-23-2011, 08:41 AM
SHAWD10's Avatar
From the February 2011 Acura Service News Bulletin, there is a chart that states:
DPSF is acceptable for 2009 to present TL SHAWD. In fact, it is acceptable for all Acura SHAWDs except for 2001-2006 MDXs which still need VTM-4.
Old 04-23-2011, 08:09 PM
vinnier6's Avatar
so where do i find that dpsf stamp at...
Old 04-23-2011, 08:55 PM
vinnier6's Avatar
i just got done crawling under my car, it is stamped ATF right where the fill cap is...i assume this means atf-z1 is in there right now...if i take my car to the dealer will they just fill it with dpsf or should i request dpsf...
Old 04-23-2011, 09:13 PM
vinnier6's Avatar
still would be nice if one of the pro would post up some diy pics...thanks
Old 09-27-2011, 08:04 PM
mannysRL's Avatar
Just flushed my rear diff and filled it with DPSF...easy to do!
Old 09-27-2011, 09:37 PM
vinnier6's Avatar
well thats a big help....can you post up a diy for the rest of us...
Old 09-28-2011, 08:40 AM
ucf_bronco's Avatar
Yeah, like someone else said...a full DIY probably isn't necessary. Just post some pics of where to drain and fill.
I'm going to be due soon as well and I'd like to knock it out myself...and bond with my car at the same time
Old 09-29-2011, 10:04 PM
almostatlowner's Avatar
This is what worked for me. As always, safety first, and use common sense! I am not responsible if it doesn't work out for you.
Now, with that bs out of the way, on to the pics!
1.) Jack up the rear of the car at the jacking point.
2.) Lower onto jack stand points.
3.) After making sure the car is secure on the jack stands, crawl under and locate the fill (top) and drain (bottom) plugs on the rear differential. You will see 'ATF' stamped below the fill plug.
4.) I strongly recommend loosening the fill plug first and the drain plug second. You might need a breaker bar. Although I didn't use one, the bolts on my car seemed like they were torqued really tight. I had to lay perpendicular to the car directly under the diff to get the best leverage.
Fill Hole
Drain Hole
5.) Grab your drain pan, then take out the drain bolt and let the fluid drain. I guess if you are really anal, you should lower the car back on the ground to get all the oil out. I didn't want to screw with it since it was mid July and 100deg in my garage. Plus, I'm too lazy.
6.) Grab a new drain crush washer (Honda 90471-PX4-000) and tighten to 33lb ft. Of course, Honda had to make the drain and fill washers different sizes. I've never seen a car use so many different sized crush washers. I went to my local Honda dealer and gave him the part numbers, at which point he just gave me two bags free! Give it a shot. Yours may too.
7.) Add 2.65qts of auto trans fluid. You will need a bottle pump to pump the fluid into the diff. I ordered mine from Amsoil with the fluid since I was too lazy to make an extra trip to the store. Stick the tubing into the fill (top) hole and start pumping away. On your 3rd bottle, just keep pumping until fluid comes out of the fill hole. Reinstall the fill plug with a new crush washer (Honda 94109-20000) . Torque to 33 ft lbs.
NOTE...the torque settings are from Amsoil. They didn't list the rear diff settings, so I used values they gave for the front.
Lower the car, take her for a spin and check for leaks!
It is a very simple and straight forward job. Good luck!
Gary
The following 11 users liked this post by almostatlowner:
Buffa (01-21-2012), clark_kent (12-02-2011), Jackieee_TL (05-01-2014), lji (09-30-2011), MoAbbas (06-11-2013), mr_raja (12-02-2011), patcracks (09-30-2011), shurik74 (09-16-2012), ucf_bronco (09-30-2011), vinnier6 (10-12-2011), vtec260 (11-17-2013) and 6 others liked this post. (Show less...)
Old 09-30-2011, 07:25 AM
vinnier6's Avatar
is there only one drain plug...i was told there was two, one in the front like you show, and one on the side....can you confirm...
thanks for the pics and the write up....
we need to sticky this
Old 09-30-2011, 08:55 AM
ucf_bronco's Avatar
Gary, you are THE man! Thank you so much for taking the time to post that. I will be doing my first one soon and after that will never have to look at this again, but having guidance to get me through that first run is essential.
I, and I'm sure many other members, really appreciate this!
Now if we can just get this moved into that new DIY subforum I'm wanting
Old 09-30-2011, 11:27 AM
vinnier6's Avatar
does anyone know if there are other fluids that can be used in lue of acura dpsf or atf z1 for the rear diff....can i use mobil 1 atf fluid?
Old 09-30-2011, 01:50 PM
mightl's Avatar
Thanks Gary! what is your DIY cost? and how long does it take for the entire process?
Old 09-30-2011, 07:50 PM
Hmmm. That's a good question. I've never heard of more than 1 drain plug. I had a few other pics of the diff, but they were pretty much the same shots.
Hey no problem. I too was tired of everyone saying it's easy yet no pics. Someone has to do it sometime, although I am a few months late!
Another good question...I'm guessing M1 would work, but I'm no expert either.
No problem. I didn't really do this myself to save money. I just wanted to know it was done right, or at least what I thought was right. Amsoil is one of the most $ you can buy. It was $11.50/qt + shipping, and the pump was ~$11. You can definitely find cheaper alternatives at your local auto parts/Walmart stores. Hmmm, I'd guess the process would take about 40min or so? It's hard to say because I always take my time, especially when jacking the car up (although I think the tires were still touching the ground). Plus, I had done my 2nd oil change and rotated the tires, so by the time I got to the rear diff, I was getting a bit winded. The first change is always the longest since you're being extra careful and double checking yourself on everything.
Old 10-01-2011, 10:28 PM
vinnier6's Avatar
so how do you know that amsoil atf was good to go for the awd system in the acura....
Old 10-04-2011, 08:45 PM
I looked it up on their website and ran with what was listed.
Specs
Old 10-05-2011, 01:57 PM
Loli's Avatar
Mine was done at 1509 miles w/ balance and rotate wheels. Also purchased 2 screws for the air filter cover. Total cost was $157.00. They told me it needed to be done at 15000 and then every 30000 after that.
Old 10-11-2011, 09:49 AM
vinnier6's Avatar
just knocked this out myself....took just under 3 qts of dpsf....
btw, whoever said dpsf was clear or carmel in color is either color blind, or i am...
its not quite as red as the atf z1, or any atf for that matter, but it is still pink in color...
Old 10-12-2011, 12:34 PM
6th Gear
axelbay's Avatar
Specs
Be careful. Amsoil does not recommend anything but OEM fluid (DPSF) for the rear differential for 2011 and 2012 TL.
Atleast that's what's on their site right now.
Old 10-12-2011, 01:50 PM
vinnier6's Avatar
btw, the fill plug was on soo damn tight that i had to use my foot to break it loose...
Old 10-13-2011, 06:03 AM
Little Gator's Avatar
And so how is the front diff. done any differant?
Same fluid? or gear lube?
Same service intervals?
Old 10-14-2011, 06:25 AM
So how did you manage to get the correct fluid level if the car was jacked up in the back which also your diff. out of level?
Old 10-14-2011, 07:11 AM
vinnier6's Avatar
i cant speak for the other guy, but i didnt jack my car up....
Old 10-14-2011, 07:19 AM
Prime Mover's Avatar
A bit off topic but I liked seeing where the rear jack point was in that first pic. Is there anyplace in the front where you can safely jack the front wheels off the ground?
Old 10-14-2011, 11:35 AM
See:
https://acurazine.com/forums/2g-tl-1999-2003-98/floor-jack-lifting-points-703995/
reply # 18
The model shown might not be the same as yours, but the jack points are the same.
Old 12-02-2011, 09:18 AM
clark_kent's Avatar
Thanks for posting those pictures Gary!
I just did mine this morning and it was easy thanks to your pics!
Old 04-11-2012, 05:53 PM
Strosek's Avatar
I also noticed that Amsoil listed that they recommend dealer fluid only for the rear Shawd fluid and not Amsoil products....
Did you notice any changes it the way the car drove?
I plan on using Amsoil in the entire car exept the rear diff because if they had something that would work believe me it would be listed.
Old 04-12-2012, 10:41 AM
jmkenn0's Avatar
Mine came on right at 10,000 miles (2012 MT), the dealership said it was either hilly conditions or agressive driving
With oil change and diff change, came to ~$170.
Old 04-12-2012, 01:31 PM
Love Guru
mr_raja's Avatar
I might be wrong but I think I saw the manual asks for the diff oil change at 15k miles, 7500 will be a bit too early.
Old 04-13-2012, 09:50 AM
lji
lji's Avatar
Mine came on around 14,7xx miles. MID shows B16 service. Took it to the local Honda dealer as the Acura dealer wanted $$$. Quick question for those that have done the B16 service in 09 and 10 TL's, which fluid was used? ATF-Z1 or DPSF??
Old 04-13-2012, 01:47 PM
white_sh's Avatar
Which Honda dealer/Acura dealer did you take your car to? How much was the quote they gave you?
Thanks,
Quick Reply: SH-AWD diff fluid...
