Running racing fuel in a 2012 TL J35Z6.
Old 02-08-2016, 08:39 PM
Joel Torres's Avatar
Would running a higher octane such as racing fuel or like 95 to 101 octane ruin the engine?
Old 02-08-2016, 09:19 PM
JJones91's Avatar
It would be a complete waste of money. Period.
Old 02-08-2016, 11:08 PM
TheMuffinMan's Avatar
And what exactly are you hoping to gain from this?
Old 02-09-2016, 12:20 AM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
This might help
Old 02-09-2016, 08:45 AM
wreak's Avatar
Originally Posted by azuser
lol
Old 02-09-2016, 08:48 AM
Received 8,712 Likes on 6,719 Posts
Whatever you do, just don't drink it...
Old 02-09-2016, 11:00 AM
HeartTLs's Avatar
If you're not tuned for it you won't benefit from it, it can actually hurt performance. Compression ratio's determine what grade is best for an engine.
Research compression ratios and how a combustion engine works.
Old 02-09-2016, 11:24 AM
Well at one fillup. I used shell V-Power with nitro and then added a octane booster and felt a difference all throughout my power band. Just wondering if running a even higher octane would give me more response.
Old 02-09-2016, 11:27 AM
Originally Posted by AZuser
Before coming here. Ive read about high octane gas and all. Just cant find the compression ratio for the J35Z6 engine. And it doesn't hurt asking around instead of just reading other options that aren't for Acura's.
Old 02-09-2016, 12:01 PM
nist7's Avatar
Received 1,094 Likes on 749 Posts
You might be feeling a small difference if you were using less than top tier gas and the v-power did some cleaning as it goes through the fuel system. Get a good bottle of Redline SI-1 fuel system cleaner.
Any higher octane will not do anything. Racing fuels are only beneficial for racing-built motors....regular cars will not benefit from racing octane.
Not to mention they are very expensive and very cumbersome to filll up each time...
Old 02-09-2016, 02:06 PM
Thanks. Thats the info I wanted to know really. I will try that redline si-1 and see how she feels.
Old 02-09-2016, 04:10 PM
nist7's Avatar
Yeah an older member on here who also was active on the s2000 forums liked the redline SI-1 cleaner and the s2ki forum had a good feeling about it too...one of the few things that may actually work compared to the million other fuel system cleaners out there...
Old 02-09-2016, 04:15 PM
Well I honestly dont need a fuel cleaner. Since ive had the 12 TL. Ive only runned 93 octane. So I'm taking that the J35 is fuel injected. I'm still new to all this car stuff. Just trying to find the right mix to get the most out of my TL and having her running good.
Old 02-10-2016, 12:11 AM
csmeance's Avatar
Received 2,013 Likes on 1,432 Posts
Redline SI-1 is one of the better fuel cleaning additives in the market and it boosts octane by several points! What several points means 1/10ths of a point! SO 93 octane can become 93.7 octane depending on the additive. Same with all other octane boosters. The reason it feels faster is probably the gas you got has 0 ethanol. Ethanol has less energy per unit than gasoline, but it's higher in octane. Good if you can take advantage of it but bad for naturally aspirated engines. Also our engines aren't "direct injection" but port injection where the fuel is dumped before the intake valves, not the combustion chamber. That's in the new TLX's and earthdreams engines.
Running higher octane fuel won't do much with a factory ECU/tune. If you have a setup where you can take advantage of the extra octane then it helps such as a turbo or s/c setup.
Also some higher octane fuels have less energy than gasoline making the car have worse efficiency!
Flipster23
Norcal
262
05-04-2023 02:47 PM
Quick Reply: Running racing fuel in a 2012 TL J35Z6.
