revometer question
revometer question
sorry if this is a noob question and im not sure what its called exactly but, my revometer sits at 1 when the car is off. is it suppose to be like that or is it suppose to be at zero?
Ok. You tachometer should NOT be at 1000 rpm when you turn the engine off. Do you have any further symptoms other than the tach does not go down to 0? What kind of car do you have, year, make. Your in a 4G TL forum so I will assume that you own one. Correct me later if I am wrong. The manufacturer ships the unit with two fuses removed under the hood to conserve battery power when shipping. Dealer puts the fuses back in during dealer prep. If the fuses are still not installed by the dealer you will have a heck of alot of issues with either the interior lighting since that is one of the fuses. The other fuse goes to the combi meter (the part with the revometer in it) and the audio unit and HVAC ECU. Put the car in accessory 1 positon. If nothing lights up on the HVAC or audio LCD screens the fuses are still missing from thier slots.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
