Reverse Led 2013 tl help
Old 07-09-2017, 09:07 PM
ron3.7's Avatar
I want to replace my stock 921 reverse lights with 921 LEDs is it going to set off a code that I have a light out? And how hard is it to do I can't seem to find a video please help want LED reverse lights just not sure how to go about it
Old 07-09-2017, 09:23 PM
LostProphet's Avatar
It is not going to set any code. I installed 921 Philips led bulbs about a year ago and not a single issue, it is a great upgrade. Remember to change the orientation (polarity) of the led bulb if it doesn't light up in the first try. Watch some videos online about how to install led reverse bulbs in any car to have a general idea.
Old 07-09-2017, 10:14 PM
The inconvenient truth
dopeboy1's Avatar
There wont be any codes. Install is really easy. Open the trunk, remove the screws and clips that hold up the carpet on the back of the trunk behind the taillight. Move the carpet back and you will see 3 bolts that connect to the taillight, remove their 3 nuts. Lightly push on the back of the 3 exposed screws to remove the taillight from the car. Rotate the back of the reverse light bulb and pull it out of the housing. Pull out the stock bulb and replace it with the LED bulb. Then put it all back on in the reverse order.
Old 07-10-2017, 05:00 AM
ron3.7's Avatar
Will try
You do realize this is on a 2013 Acura TL SHAWD?
Old 07-10-2017, 10:37 AM
dopeboy1's Avatar
Well that is how I did it on my 2012 Acura TL SH-AWD. I am sure your 2013 is quite similar if not exactly the same.
justnspace (07-10-2017)
Old 07-10-2017, 11:39 AM
Keeping TL until 2029
echodigital's Avatar
There are a bunch of videos on this site...
https://www.carcarekiosk.com/video/2.../reverse_light
Old 07-10-2017, 07:19 PM
ron3.7's Avatar
Thank you
Thank you very very much I've been wanting to do this for a while now I'm on a mission.
