Reverse Gear Vibration
Old 01-19-2020 | 07:45 AM
Kinuto's Avatar
As the title states my 2013 Acura TL FWD model is experiencing a slight vibration whenever I put the car into reverse and place it in park. All other gears are smooth. The transmission fluid has been changed 3 times every 20k the car is at 77k. Anyone experience this?
Old 01-20-2020 | 01:44 AM
4GTL-CBP's Avatar
Try looking underneath the car for the transmission motor mount (underneath drivers seat). Mine makes a clunk just like yours, found out I needed a simple trans mount from Acura for $45. Simple to do once the car is up in the air.
Old 01-20-2020 | 08:18 AM
Kinuto's Avatar
Definitely gonna look into it. I'll change the transmission fluid and have the motor mount replaced at the same time. Thank you!
Old 01-20-2020 | 11:21 AM
4GTL-CBP's Avatar
https://www.acurapartswarehouse.com/...wd.html?PNC=11
Sure thing! I went to the parts department and had them price match the website above.
Part: (50850-TK4-A11) Rubber, Transmission Mounting (LOWER)
Kinuto (01-20-2020)
Old 01-20-2020 | 11:40 AM
Kinuto's Avatar
Thanks again! I love this car. Any little problem I notice I'm quick to repair it.
Old 01-20-2020 | 11:45 AM
4GTL-CBP's Avatar
Definitely! I just drain and filled my rear differential, transmission and also my transfer case. So it's good to go for another 6 months plus! It's cheap insurance compared to replacing any of those components.
Also changed just the PCV, simple and your could do it your self with a 10mm.
Charlestennison
02-07-2019 11:58 AM
nokkieny
02-21-2012 12:25 PM
2k6ATL
12-22-2011 01:01 AM
habaguba
05-01-2010 09:30 AM
