Repair Droopy Sun Visor?
The sun visor on the drivers side has been loose for quite a while. I cannot figure out how to remove the plastic cover to see if the screws are loose, or that the entire thing needs to be replace. Has anyone out there popped of that little cover, and if so how?
Bottom of Page 1792 and 1793 of the Acura Repair Manual
see thread https://acurazine.com/forums/fourth-...manual-956811/
for the manual
1. Insert a flat-tip screwdriver through the hole in the front side of the bracket cover (A), and push the hook
(B). Make sure the hook is unlocked.
2. While pushing in the hook (A) with a flat-tip screwdriver, release the sunvisor (B) from the holder (C),
and rotate the sunvisor backward about 45°. Make sure the hook slides into the bracket cover as you
3. Pull down the sunvisor (A) to release the pin (B) and the bracket (C) from the holes in the body. Then
pull out the vanity mirror light connector (D), and disconnect it.
Manual had pictures that better describe it.
for the manual
The following 2 users liked this post by Anicra:
echodigital (05-15-2018),
Papa Roe (05-18-2018)
xedap1998
07-19-2005 10:54 AM
