Rear Quarter panel rust
Does anybody know where i can find the precut metal fenders to replace existing quarter. I am not talking about the whole panel just maybe 4 inches above the bottom of the fender. I had a shop try to look up panels but only find panels for honda. thanks in advance.
something like this
fender
something like this
fender
This will not help you; the picture clearly shows that this qurter is a sculpture made of bondo. The best option in your case is to made the same sculpture from fiberglass bondo and sale the car, or replace 7-10 inches above. And if you are sure that you need 4 inches, then buy a front fender and cut a piece from it.
That rear panel is terrible because it's just a lip and a lot of crap can get in there. You need to clean it and add build up the area with sealant so that water and dirt will bead down from it. I have filled my up so it's a 45 degree angle so nothing stays there too long. You still need to clean it after the winter and reseal it when you change your tires.
