Questions
Old Aug 12, 2017 | 12:02 PM
Chrispy225's Avatar
Questions
Questions:
Anybody have a guide on installing rear coilovers?
Do I take the back seats out or go through the trunk?
I'm trying to get new genuine OEM bolts for my rear 3 arm tie bar camber kit. Does anybody know the part number?
Thankssssss!
Old Aug 12, 2017 | 12:24 PM
oshiha's Avatar
You'll have to take the back seats out. Start by removing the seat cushion (theres 2 pins you have to unlatch underneath, in the middle of the left and right seats. You'll have to pull this piece so it unlatches). Remove the side piece trim.
To remove the back rest, theres 4x10mm bolts that are exposed once you remove the cushion. Once those are out, theres 2 hooks ( one in the middle of each side of the back rest ). To get them out, push into each side and pull the seat up. You'll feel it come off the hook. That'll expose the top of the struts.
Good luck, it was a bitch taking out the back seat for the first time. Now, it takes me 10 minutes LOL.
This should help with the bolts:
https://www.acuraoemparts.com/auto-p...lower-arm-scat
