Oil consumption observation
I own a 2012 TL SH AWD with 45K miles. My normal driving pattern is a 10-15 mile commute to my offices 5 days per week with many shorter drives on the weekend. The car has consistently used one quart of oil per 4K miles. The oil usage is linear from the time I change the oil. One quarter of a quart per thousand miles no matter how far along in the oil change I have traveled. It does not change in the heat of summer or the frigid temps in a New England winter. I have used various 5W-20 synthetic oils and have found no difference in consumption. This is not complaint session for me. Just means an additional quart between oil changes.
I have noticed that if I use the car for an extended drive, the oil consumption drops to zero, zip, nada. Last year I drove to Myrtle Beach SC which is about a 900 mile drive. Outside temp ranged from 95-100. Speeds of 75-80 mph with only bathroom and refueling breaks. I checked the oil prior to leaving and it was exactly on the full mark after sitting overnight. Did some local driving down there to restaurants but not much. Returned home under the same conditions. When rechecked at home after sitting overnight, the oil level was exactly on the full mark. 1800 miles with not a drop of oil usage.
This year I did a drive to Cleveland for a family event. Ambient temp was 80. Speeds were 65-70. 1200 miles round trip and had the same result. Not a single drop of oil use!
Not sure conclusions can be drawn from this limited sample, but perhaps the oil usage occurs when the engine is cold and warming up. If so what might be causing it?
There is a acurazine member who took his car to acura. they had the okay to tear down the engine.
there seems to be a problem with the pistons and the ringland.
His piston and rings were replaced under warranty, however, he said he's still losing oil after the engine rebuild.
At this point I believe oil consumption is directly proportional to RPM. The higher I rev my car, the more oil I lose. I am in the same boat as you, although my consumption averages slighly less than yours. But I have discovered that I lose a lot more after spirited drives and almost none after lonh highway driving.
Sorry for the total noob question... but how do you detect and keep track of the quantity of oil consumption? Regularly check dip stick? How do you determine exactly how many quarts you're losing?
I check the dipstick after letting the car sit overnight in my garage.
To clarify... how many quarts are equivalent to the delta height of 'full mark line' and 'add mark line' on the dipstick?
Also... there are different 'ring' levels where the dipstick handle goes into the hole. I can stick it all the way in or I can stick it in up until the plastic ring and feel it clip. Which is the accurate way to get a good measurement, all the way in or partially in? Thanks in advance!
This seems to only happen on the 3.7. I had my short block replaced under wranty at around 65,000 miles. There is a oil consumption thread on here already.
Here you go.
https://acurazine.com/forums/4g-tl-problems-fixes-297/oil-consumption-784028/
Here you go.
The moral of the story is TRADE IT OFF. If you are so unlucky as to receive/buy a car with one of these major issues (or weird tranny, electrical, etc problems) get rid of it.
So... any real details on why it's happening? Did Acura say anything officially?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
