Noob Enthusiast Bulb Question
Hello All, I'm wanting to change my DRLs and Foglights to a different bulb, preferably a white color instead of the amber yellow. My question to you guys is, is there such thing as a plug and play kit/bulb set that will not cause any errors to appear on the car?
Thanks!
Thanks!
The inconvenient truth
For fog lights yes, mine are straight plug and play replacement LED bulbs. For DRLs... sort of, mine came with resisters that need to be mounted to a metal surface. My DRL kit came with the resisters already hooked up to the bulbs so you just plug and play the stock bulbs with the LEDs and then mount the resisters. Both have been flawless and don't throw any codes.
Titan_X (07-27-2017)
Keeping TL until 2029
I have upgraded DRL and Fogs to DRL. There are lots of discussion on it...
https://acurazine.com/forums/fourth-...-953482/page2/
These are my fog lights
These are my DRLs
Be aware that LED DRLs do not have a high beam function. They are low beam DRL only. So do not buy them if you need a high beam. I've never missed having high beams as I drive mostly city and my headlight/switchback/fog light combo is bright as f**k.
https://www.amazon.ca/JDM-ASTAR-Extremely-Bright-Chipsets/dp/B01BEPWOP8/ref=sr_1_1?ie=UTF8&qid=1501254768&sr=8-1&keywords=2012+acura+tl+drl+led+jdm+astar
These are my DRLs
https://www.amazon.ca/iJDMTOY-16-CREE-9005-LED-High/dp/B01I0I5T5Y/ref=sr_1_fkmr1_2?s=automotive&ie=UTF8&qid=1501255649&sr=1-2-fkmr1&keywords=2012+acura+tl+drl+led+ijdmtoy
Titan_X (08-01-2017)
https://www.amazon.ca/JDM-ASTAR-Extr...+led+jdm+astar
These are my DRLs
https://www.amazon.ca/iJDMTOY-16-CRE...rl+led+ijdmtoy
These are my DRLs
The fogs have been great. I haven't had them for long but so far no problems. I copy and pasted the following from the ad.
6000K xenon white color
Lighting Output:1500 lumens for each bulb.
Application: Fog lights , DRL.
Waterproof: IP65. Voltage:12V to 24V. Wattage: 8w.
Lifespan: 10000 working hours. Non polar design
Derived from European union E4 standard design
Excellent heat dissipation design for maximum performance
Improved brightness, which will benefit your driving experience
compatible with most American, Japanese ,and European vehicles. The bulb might throw the error code for some vehicles with built-in canbus system
If you have a 2012+ i've heard great things about these fog lights:
https://www.theretrofitsource.com/al...ect_restrict=1
If you don't (like me) then these led lights for your fogs on your 2011 and below are amazing. I have them installed on my '09 sh and they cover the entire road with really bright cool white/blue light:
The retrosource fogs were like 20 minute to install. Took me longer just aim them. I tried other LED fogs none needed a resistor. All of them seem to send the light everwhere except what was useful. I wanted the yellow LED for fog/snow and such so I had retrosource apply the Lamix yellow film on the lens before they shipped them. The DRL take even less - one side just pull up the coolant container and the other was remove the battery. I was replacing the battery with Odyssey extreme deep cycle and giving my slightly used battery to a needy friend. It is really fast replacement if you notice the tooth orientation instead for trying the 3 possible ways.
Lets not talk about the HID bulb on the passenger side. I figured I would upgrade to the Osram nightbreaker. Since my wife's friend has some major camera equipment and noticed that the factory HID were about 10 pct less right over 4 years. Since the spot she parks was the same spot, they were able to compare. You need stick thin arms and thumb immune to pain. My thumb was numb for 10 days. Pulling off the bumper was the only solution for me. Because the lever would not move.
Morimotos are sweet. I had to go with normal bulbs because I have a 2009 TL. I found this video helpful.
How hot do LED headlight bulbs get? ? Better Automotive Lighting
IMHO, the newer LEDs are really good now and High Beams are a non issue.
Reviving an old thread here.. I've been looking at doing an LED DRL conversion; why do you say that high beams are a non-issue? Is it that the LEDs are bright enough that they aren't needed? I live in a rural area with lots of roads that aren't lit very well and I use my high beams almost every time that I drive at night.
Yeah if you drive at night in a rural area make sure you buy good ones with a high beam function. Im looking to buy LED DRLs that have both high and low beam function and also match my "6000k xenon white" switchbacks. For the life of me I cannot decide which ones to get lol.
Pictures pls for sure. Which ones did you get the $150 ones?
It was these R5 HIGH/LOW DRL MICRO WITH VOLTAGE BOOSTER KIT - Acura - 9005 HB3 - Daytime Running Lights - Shop Application
They came out to 170, they're having a fall discount and free shipping right now. I'll try and get them installed this weekend.
I think im going to try these ones
They are $70CAD shipped to my door instead of 170USD for the vleds. They have the same warranty and at least claim to have higher lumen output than the vleds do.
https://www.amazon.ca/gp/product/B07...93JH6X0N&psc=1
I got the VLED bulbs in today. If I’m not working tonight I’ll put them in and post some pics.
you get what you pay for
Those do intrigue me, however the VLEDS claim to be engineered to work as both DRL and high beams, whereas these are apparently only highs. Still, if you do go with these, please post an update with your impressions.
Very often true, however these claim to have a bit over 1,000 more lumen per bulb, and come with a 2 year warranty (as opposed to 1 year for the more expensive lights). Warranty is not, of course, 100% correlative of quality; an item with a short warranty may well last forever, while an item with a strong warranty could need several replacements (and with headlights, replacing them is a PITA). But both sets look like they might do the job. Thus my intrigue, though I'd like to see someone else guinea pig them.
Ill be your guinea pig. Not sure if I need them but Ill get these too to make sure there's no issues.
Acura's dont use CANBUS.. just get some resistors
VLED resistors
I installed resisters for my switchbacks where I had to splice them into the wires. The kit I bought had the clips where u just put the wire in each end and clamp it down. It was easy to do but doesn't vleds sell ones that are plug and play like the ones in the link I posted?
I'm going to take a few pictures of the lights when it gets dark this evening btw.
I did a lil bit of research for quality LED's and I decided to get Drls, fogs and switchbacks from Vleds a week ago. This Drls had the hyperflash module included. Fogs were plug and play and the switchbacks came with the base adapter but the module was sold separatly. Unfortunately, all but the fogs were backordered. I should receive them all mid November.
Here is the links
6 XTE-2 H11 H16 LED DRL/FOG LIGHT BULBS - H11 H8 H9 H16 - Fog Lights - Shop Application
V6 TRITON 5K / 6K WHITE AMBER SWITCHBACK 3157 - Standard - 3157 - Turn Signals Front - Shop Application
Hope this helps
Here is the links
Hope this helps
Here is the links
Hope this helps
Here is the links
Hope this helps
They're not as warm colored as this pic makes them out to be, I guess it's something to do with the camera on my iPhone. Either way they're bright and look a lot better than the halogen DRL/high beams.
F*ck! im gonna get in touch with Vleds.com to see if theres a fix for that. Not interested on having the replace DRL warning popping everytime. I'll keep you posted on their reply
Yeah, it's probably the most annoying thing I've experienced in a vehicle. Every few minutes 'ding....ding ding..." I think you're gonna have to get some of the resistors but keep but updated on what they say for sure.
If you are in Canada, I got mine from tdotperformance (PUTCO). I replaced DRL and FOGS. You can check them out here:
I may only do rear light replacement to LED's. I don't want to add resistors. I have been told by @Christopher Michael that these work well without resistors for signal lights.
http://www.vleds.com/shop-applicatio...it-a-7443.html
Good luck!
Good luck!
They look really nice. Sucks about the drl warning though. I bought the ones I linked from amazon and they should be here by next Friday. Ill post some pics when they are in.
