New toys make for happy boys!
done in exactly 1 hr 10 min. Does not include time to start compressor and jack up car. I had a couple of issues...
1: I had 1 stripped nut on the J-Pipe while taking it out (I was rushing)
2: Could not find a couple of my tools (I blame this on the wife)
3: there are 4 tabs on the Cat, that I don't think should be there. One became a big PIA when trying to get one of the bolts tightened. If I had take a little time to look around, I would have removed these prior to install.
4: I'm just not as fast as I used to be, but very happy I did not need to pull out the oxy-acedelyn torch.
I'll give it a butt-dyno and let you know what I think in a little bit. I'll probably do some magnaflows later on as well.
Received 6,470 Likes
Congrats.
OG
Does your J pipe touch the transfer case like mine in this thread? https://acurazine.com/forums/4g-tl-performance-parts-modifications-295/people-have-xlr8-j-pipe-861101/ Just curious, when did you order your J pipe and when did you receive it?
Does your J pipe touch the transfer case like mine in this thread? https://acurazine.com/forums/showthread.php?t=861101 Just curious, when did you order your J pipe and when did you receive it?
Almost made one of the install... was thinking of putting the GoPro on, but decided that it would probably get in my way and slow me down. I have some pics I'll put up soon.
No good butt-dyno yet, as I have been toting my daughter around, and don't drive fast with her in the car.
Install pics
Pics of the install... You can see in the last pic that I partially stripped a nut. This was a bit if a tight fit getting that bolt out, and even tighter getting it back in. In the 2nd to last pic, notice the tab, that I had to bend down. If you get the hi-flow cat from xclr8, I think it would be best to remove all 4 tabs prior to install.
I didn't bother weighing the parts, but the new j-pipe/cat are definitely lighter than the OEM parts.
There as a bit of a funny smell on the first 2 drives, but that is probably just some burning off, or the new cat... I expect it should be gone in another drive or 3.
Last edited by CerberusKy; 07-11-2012 at 11:15 AM. Reason: missed a pic, more text
Joseph Stansbury
34
12-04-2015 01:57 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
IndycarFaster
09-11-2015 02:52 PM
