Need help finding parts for my Acura 😭
I have a Acura TL 09 3.5L FWD and I’m looking for a front wheel hub and bearing assembly. I have not found a site that’s has the assembly. If anyone can post a link or let me know the website that would be greatly appreciated!
Sidsadat123 (03-31-2021)
2016 Acura TLX
Try oemacuraparts.com. They are a Acura dealership in AZ that sells parts wholesale online. Also super friendly if you call them and ask questions.
https://www.oemacuraparts.com/oem-pa...Y2LWdhcw%3D%3D
https://www.googleadservices.com/pag...BAgBEDU&adurl=
Quick search and you would have found it
That has the 2-3 parts separate but not the whole pressed assembly.
You're not going to find a pressed assembly.
Because...how would you install that?
Pressed assemblies are for cars that use bolt-on wheel bearing assemblies.
This car's bearing is first pressed into the knuckle using the OUTER race.
Then the hub is pressed in by supporting the INNER race while pressing the hub into the bearing.
That's important to follow...or you'll need a new wheel bearing immediately after you're done installing a new wheel bearing.
SamDoe1
09-27-2024 09:00 AM
BBsAcuraRacing
08-20-2002 09:46 AM
