AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   4G TL (2009-2014) (https://acurazine.com/forums/4g-tl-2009-2014-123/)
-   -   Motor Mounts (https://acurazine.com/forums/4g-tl-2009-2014-123/motor-mounts-1011446/)
Big Dom Oct 22, 2025 04:54 PM
Motor Mounts
2012 Acura TL Base
Took a video but decided not to post. Pretty obvious that when I power brake (in Drive), the engine lifts up pretty good. No in reverse though, reverse was fine. So, assuming the front mounts are bad?
Should I assume transmission mounts are bad, too? (Maybe this explains my other post regarding how the transmission feels "different" to me; maybe its a mount issue).
The million dollar question: Do you kind folks recommend anything other than OEM for motor and transmission mounts? Did some pricing today on Acura OEM Parts - WOW! $600 for the 3 mounts.
Thank you.
csmeance Oct 22, 2025 07:11 PM
how many miles on the car? City or highway or mix?
OEM motor mounts are the way to go most of the the time. Most aftermarket ones don't last or don't have the vac lines that stiffen the mounts when you get on the gas.
Rear mount cushions most of the vibrations, esp when you are in a red-light and in drive. Do you have vibrations at a red-light in drive?
Big Dom Oct 23, 2025 01:58 PM
Thanks for your reply!
2012 with 110K miles.
So I do not notice any vibration at a red light and in drive. Very quiet actually. I dont even notice a bad mount when coming to a stop (you know that weird little feeling right before the car fully stops). I didnt even notice it when pulling into my driveway which has a small grade/hill. I only think about mounts because of how the transmission feels "different" to me. Maybe its the transmission mounts? But also, when I power braked in Drive, the engine lifted up more than it should. When I go to mechanic next week for trans service, I will ask him about if I need mounts and which ones (although I assume all 5 should be done together). Sorry for my possible inability to properly explain. Trying!
altair47 Oct 23, 2025 08:26 PM
A few months ago I bought a complete set of engine mounts from Anker, I'll try to install them this weekend, otherwise driving with 3 out of 4.5 completely torn mounts is not very pleasant.
Big Dom Oct 24, 2025 10:39 AM
Good luck this weekend!
altair47 Oct 24, 2025 08:29 PM
Thanks, I've almost finished it in two hours, but the radiator didn't survive(-$175, but he is 16 years old, so I was not upset.). There's not much room at the front, and touching the sharp side of the mount to the 16-year-old radiator resulted in a tiny, almost invisible micro-stream. So, be extra careful.
At 200,000 miles, the front was completely torn off, the rear was almost torn off, but dry. The mount on the transmission side was full of microcracks, worn out, and flexed twice as much as a new one. But the mount near the ABS seems better and more durable than a new one, so I'll probably keep it.
Big Dom Oct 25, 2025 02:41 PM
Nice work!
Tuesday mechanic will inspect mounts. Guessing mechanic will do more than just "power breaking"? Kinda how you inspected and gave your feedback.
New radiator - that's OK! 16 years - holy smokes.
altair47 Oct 25, 2025 03:07 PM
Originally Posted by Big Dom (Post 17003926)
Nice work!
Thank you.
The Power Breaking Test said three mounts were gone, but in fact, only the front and rear ones need to be replaced. I finished everything today and only left the removed fan so I can replace the radiator on Tuesday (RockAuto is our everything). With my experience working on these cars, I can say it took me up to three hours to replace the front, rear, and upper transmission mounts. If you take your time, all four upper mounts can be replaced in four hours. The only equipment required is a good daytona or snaop-on jack and piece of 2x6 wood. Car lift is not required.
thoiboi Oct 25, 2025 03:32 PM
Originally Posted by altair47 (Post 17003931)
Thank you.
did you need to drop the subframe
altair47 Oct 25, 2025 06:02 PM
Absolutely not, in the fourth generation TL this job is done simply. The main thing is to be careful with the radiator:jesuslol:
csmeance Oct 25, 2025 07:24 PM
Time to call my buddy the pizza box to save the radiator when I have to do the job, or maybe a scrap piece of plexiglass! Great to hear how you did the job, your information is always epic and valuable!
altair47 Oct 25, 2025 07:52 PM
Thank you very much, yes, I was thinking about getting some thin sheet of plastic to avoid similar situations. At 2022, my wife hit a deer, and now the radiator looks like this. I keep waiting for it to leak so I can replace it, but it never gives in. And this time, I honestly barely touched it and that was it.
https://cimg2.ibsrv.net/gimg/acurazi...e0e2e3ddac.jpg
Big Dom Oct 25, 2025 09:09 PM
expert motor mount installer! Ever install in las vegas!?
altair47 Oct 25, 2025 09:12 PM
😁 No, I'm installing in Delaware.😁
thoiboi Oct 26, 2025 11:52 AM
is the radiator too difficult to remove? it would give you a bit more room to work as well no?
thoiboi Oct 26, 2025 11:53 AM
lucky... radiators are easier to replace than dropping subframes :bored:
Big Dom Oct 26, 2025 12:00 PM
Delaware? Lived there for19 years before moving to Vegas (originally from Philly). #Bear
altair47 Oct 26, 2025 04:16 PM
Removing the radiator is not difficult, but there are issues with the transmission fluid lines, and there is always a good chance the old radiator may not survive removal and installation.
altair47 Oct 26, 2025 04:19 PM
On which Acuras or Hondas is it necessary to drop the subframe?
thoiboi Oct 26, 2025 10:49 PM
It may just be my ignorance, i thought the subframe had to be dropped to do the motor mounts on the 3rd gen TL :tomato:
altair47 Oct 27, 2025 07:15 AM
When I started working as a mechanic 10 years ago, I may have actually lowered the subframe a bit on the 3rd-generation TL, so maybe it's necessary, or I just did it wrong. Although Mitchell gives even less time for this job than on the 4th-generation TL.
zeta Oct 27, 2025 10:03 AM
:chuckle:
This is the extent of concentrated guidance the FSM gives in regards to 3G TL engine mount replacement.
One can find 'piece meal' information; however, you'd have to go through the 'Engine Assembly' areas of the FSM to find it.
https://cimg9.ibsrv.net/gimg/acurazi...7f346e50dd.png
https://cimg0.ibsrv.net/gimg/acurazi...d3a6d1f7f9.png
:ugh:
:scratch:
:rofl:
altair47 Oct 28, 2025 08:42 PM
Honestly, I didn't enjoy of this experience because the trans lines are underneath, and because of the installed splash shield, I had no desire to get under the car at all. Replacing the radiator on a car lift should be a very simple job.
But I spent 1.5 hours on this job.
https://cimg3.ibsrv.net/gimg/acurazi...7a57cfc4cb.jpg
https://cimg4.ibsrv.net/gimg/acurazi...a3353f6f58.jpg
altair47 Oct 28, 2025 08:45 PM
But there are no more idle vibrations, and vibrations during slow acceleration at low speeds have disappeared.
csmeance Oct 29, 2025 07:27 PM
glad to hear this! Please let us know how the ANKER/ANCHOR mounts work out!
altair47 Oct 29, 2025 08:02 PM
Time will show.
altair47 Oct 31, 2025 08:46 PM
I asked and now I'm answering. I was doing some engine mounts on a 2010 MDX today. I had to unscrew the subframe bolts, bend it back, and lift the engine to remove old mount, otherwise I'd have to just drop the subframe.
thoiboi Oct 31, 2025 09:57 PM
k so I’m not completely insane :tomato:
altair47 Oct 31, 2025 10:09 PM
Absolutely not :workout:
rlx015 Oct 31, 2025 11:57 PM
Regarding the original question about engine mounts, always opt for OEM replacements. Just because of how big the job is, after-market mounts will fail far sooner, no matter how they up-sell their product - OEM motor mounts are always a better choice!
altair47 Nov 1, 2025 05:59 AM
No one argues that the original is better, but when you are faced with the choice of investing $200 versus $900 in a 16-year-old vehicle with 200k+ miles, then for some reason you automatically want to go with the cheaper one.
csmeance Nov 1, 2025 03:11 PM
:agree:
altair47 Nov 1, 2025 05:13 PM
Originally Posted by csmeance (Post 17004726)
:agree:
Thanks boss :thumbsup:
Flyinblyian Nov 2, 2025 03:28 PM
What about when you have a 2012 TL FWD with only 125K miles and is in excellent condition? I want her to see 200K, but I am definitely struggling with the cost of OEM vs aftermarket. Hearing that Altair chose aftermarket makes me feel a little better!
altair47 Nov 2, 2025 03:33 PM
So if you have a problem with your mount, it's most likely the front mount. Replace it separately and that's it. It costs about $250-$300 with delivery.
Flyinblyian Nov 4, 2025 08:09 AM
Thank you Altair!
Flyinblyian Nov 17, 2025 11:00 AM
More on this for other users contemplating motor/transmission mount replacement on 4G TL. Since the current plan is to keep the 2012 TL FWD with 125K miles, I decided to bite the bullet and replace both the upper/lower transmission mounts. I arrived at this decision due to some clunking when going to both P>R and P>D, was also getting moderate vibrations in D with foot on brake, as well as some wonky shifting/slight clunks on my daily drives. I actually thought the transmission was going despite my over maintaining over the past decade.
I went with OEM mounts on both upper and lower, and I have to say there is a vast improvement overall regarding my vibrations, clunking and wonky shifting. I've owed this car since 12K miles and started having flashbacks to how it felt when it was like new. We tend to forget and adapt over a decade I guess. OEM parts were around $300 with shipping and installation wasn't too bad. Took me about 4 hours from start to finish as I took my time and don't have access to a lift. Top mount was obviously easier to get to and replace.
I am now throwing around replacing the front/back/side motor mounts in 2026 when I get the rear main/drive plate issue resolved.
Just wanted to share my experience, good luck!
Big Dom Nov 22, 2025 02:56 PM
A little power break test. Between this and some vibration or "movement" while driving, I suspect I need mounts....
altair47 Nov 22, 2025 04:41 PM
https://m.youtube.com/shorts/_LyJt_dhnHw
The front one is torn off, the back one is probably okay.
Big Dom Nov 22, 2025 05:19 PM
I want OEM front, side, and upper tranny but cost.....
I bought a full aftermarket set years ago off of rockauto for my 2000 acura tl. I was very satisfied.
Debating....
© 2026 MH Sub I, LLC dba Internet Brands
