Morimoto XB LED Fogs (Type S)
Hey guys I just received the newest Morimoto XB LED Fogs (Type S) for my 2012 TL SH-AWD. Got them from http://www.theretrofitsource.com/led...ts-type-s.html
Here are my findings. The package came double boxed and very well packaged. The fogs were packed in bouble wrap individually inside the second box. There are also included in the package two plastic h11 connectors and 8 bolts to secure the fogs. The feel and look of the morimoto xb led fogs is well above my expectation. Got them for $175 plus 15% off discount. They come with a 5 year warranty. Here are some pictures of the newest fogs. I will be installing them by the end of the week on my 2012 tl. I will post more pictures befor and after later on.
speedsnice (08-12-2014)
Hey guys I would like to apply clear protection film on the fogs before installation. Which brand protection film would you guys recomend on fogs, head lamp and possibly turn signal housings. I was thinking getting lamin-x or XPEL in clear. I know that you can get 20mil or 40mil for the fogs and 8mil or 12mil for the headlamps in lamin-x but I am not sure about xpel. Any suggestion guys?
Hey guys I decided to go with suntek ppf on both headlight, turn signals and new morimoto xb led fogs. I am paying $70can for all installed. All will be done late this week. I will post pictures when all is done. I already have suntek ppf applied on front bumper, hood, fenders, mirrors, rear top fender.
Hey guys today I just completed installation of the Morimoto XB LED Fogs (Type S) on my 2012 TL SH-AWD. Installation is straight forword remove old fog housing and install new ones in the place of the old ones. It is plug and play. It took me 1/2 hr per side then wait until dusk then align the fogs from the bottom throu the openings with a flat or philips screw driver so that they are at the same level as you can see from the picture. I aligned the fogs on my garage door. My are aligned up high just below the low beam spectrum. They can be adjusted to any level very easy in no time trou the lower openings. They have very nice cut off no scatter, they have good color and I can see at night a lot furter with them being on. Here are some pictures. Enjoy.................
shurik74 (08-13-2014)
Thanks!! Original price was 175.00usd. I got it for $164.29 that included 15% discount for acurazine member and $15.54 shipping to Canada. If you are in us then $15.54 less for the set. I am not sure how much acura dealer would charge for set of the oem fogs.
How exactly did you apply 15% discount as being AZ member?
Nice pics! The CBI's that you have, are those with the stock housing or did you make any adjustments?
I have 5000K H11 bulbs in my fogs, so I'm happy with this. Thinking of going to CBIs for my stock projectors. Interested in the distance and cutoff.
https://acurazine.com/forums/4g-tl-2009-2014-123/morimoto-xb-led-fog-lights-your-tl-retrofit-source-913269/
The Osram CBI 5500K are on the stock housing no adjustments. Just make sure you get the original Osram CBI and not the cheap fake ones from feabay.
Just check this thread the info is there how to apply 15% discount at the retrofit source. Enjoy..........
https://acurazine.com/forums/showthread.php?t=913269
Here is the list of Acura cars that they will fit.
Acura ILX 2013+, Acura RDX 2010-2014, Acura TL 2012-2014, Acura TSX 2011-2013
Great news!!!! Price drop for Morimoto XB LED Fogs (Type S) from $175 to $160 plus 15% discount yours for $136usd at the retrofit source.
is the discount automatic when you purchase or is the a code you need to add?
edit: nvm i just typed acurazine as the promotion code and got the 15%. thanks! cant wait to try these on.
Just make sure you also got the plastic male H11 connectors and not 9004. You will need them to properly plug in into your factory female connector. If you did not mention about it they will send to you in 9004 style as default. Did you mention about connector when you were ordering them from seller? It is straight forward. Take old fogs out put new ones in the same spot, use the same screws to secure them. Just do the alignment at night so that both fogs are on the same high level. I did mine on garage door. Do it from the bottom thro the holes under bumper with flat or Philips screwdriver. Have Fun...
I just hope, all is going to go well with your install. Keep us inform. I just upgrated to vleds switchback last weekend. Have a great weekend!!!
finally got them on. I am very happy with how well they match my low beams. the install was easy although had to stop midway because of the rain. gonna wait till tomorrow night to make sure both are aligned well. but just looking at them now against the wall, they look pretty even.
thanks again jerry "o".
looks great!
I was just checking these out yesterday for the first time. They caught my attention and now I see you got them installed! Did you removed the front bumper? Or just used the access under the front bumper?
How-To: Install an HID Fog Light kit on a 4th gen TL
https://acurazine.com/forums/fourth-...gen-tl-863117/
