Missing left license plate light [2010 TL]
Old Jul 10, 2024 | 01:11 PM
Unrealworld's Avatar
6th Gear
I recently purchased a 2010 TL and noticed that the left license plate light assembly is missing. I checked in the bumper area and didn't even notice a connector for the light. The old owner did add backup sensors that beep when you are close to an object. I suspect whoever did the install removed one light and used the power connector for the backup sensors. I plan on ordering a new left license plate light assembly.
Would it be possible to use wiring from the right license plate light to power the left light. If so, what wiring would I need to connect to the power running to the right license plate light.
Old Jul 10, 2024 | 02:21 PM
3/8/12 here: https://www.oemacuraparts.com/v-2010...l-connector-rr
7/8/9/11 here: https://www.oemacuraparts.com/v-2010...-license-light
and yes, no issue you can't tap the right light
Old Jul 10, 2024 | 02:46 PM
6th Gear
Thanks, what's the best way to tap into the right light connector?
Old Jul 10, 2024 | 02:55 PM
t taps and blade connectors? or two posi-taps should do the trick too
Old Jul 10, 2024 | 10:46 PM
6th Gear
Any idea where I can find the gauge of the wire that goes to the license plate light assembly. I found the part but no reference to the wire size is made.
https://www.hondapartsnow.com/genuin...1-sm4-406.html
rsutoratosu
3G MDX (2014-2020)
Nov 29, 2022 01:43 PM
Xxb005txx
Oct 8, 2013 09:30 PM
tommystyle86
Feb 1, 2011 02:34 PM
VCs_TL
Sep 30, 2002 08:28 AM
dbox
May 9, 2002 07:00 AM
