Matching HID Fogs 2012
Back at it with the TL SH
Ok so i have been debating on getting matching HID fogs for my TL-Tech 2012. I think the bulbs are H11 and the stock light temp is 4300.
Does anyone know of a good HID system that would match the head lights perfectly?
Are those 4300 HID kits worth the 50?
Does anyone here own a kit?
Pictures please!
Pictures please!
Since the output of the fog lamps are 55w should I look for an HID kit that is also 55w or can i choose from the 35w crowd?
In the process of looking for a kit.
Why bother looking for a HID kit and just purchase a set of bulbs for around $25.00? Also I would stick with the factory recommended watts.
Too late Hamma, I pulled the trigger on a set of HID from Stealth Auto.
The set that i purchased is 4300K, H11 35w. I will be posting pics of the install and of the kit.
If they aren't what they say they are then i'll go out and get "regular" white bulbs.
i don't think stock fogs are hid so he did need to buy the hid kit. for installation you probably will need to take off bumper and you will need slim ballasts. make sure you don't take off the glare shield and point the fogs lowest possible. specially for 4300k they are very bright and u could blind someone. i personally setup hid 4300k lows, 6000k hid fogs and osram ultrastar halogens for DRL/highs. i kept 4300k lows because they are much brighter than 6000k HIDs. I went 6000k with fogs because they look cool, specially with TL fog light housings which i think is the best in the world...really wide beam, i think 140-160 degrees
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
