Make under dash lights brighter
#82
TL 2012 SH-AWD TECH/UMBER
I did it finally. Here is a picture , you could notice you could see the blue light that fall on the middle near the cup holder cover. I have winter floor matt.
I think the second one is closer to reality. it depends how your monitor is calibrated or not.
#83
Since those pictures, i have enlarged the hole in the driver side to avoid the shadow you could see.
What acura was thinking by putting this close black plastic car above the blue led ?. It was almost impossible for the light to go through this
#84
I'm glad someone brought this thread up. Just did mine today, took less than 10 minutes. Driver's side was easy. Passenger's side took a little bit longer cause I was scared to pull the plastic out. Followed the advice in here I worked at the side near the door first then pulled hard to detach the clip.
The light was definitely not too bright at all. Everyone with a 4G should do it. Great mod.
#87
2012 TL SH-AWD
Hi guys, I'm trying to retrofit this on my RL however. I don't understand why the led light has a cap, so where the lights out if the cover stay there without making a hole. Sorry ricky dum dum here!!! What diameter hole have you guys done to get a decent brightness.
Here's a photo how it comes from factory
Here's after I removed the cap
#93
6G TLX-S
That's why people drilled through the cap. So they can custom size the drill hole to adjust the amount of blue light coming out.
#96
I have done this mod as well, I am not to found of the blue light either. I was wondering if i covered the LED with a white vinyl piece or something that would allow the light to shine through. Which should give it a whitish look
#98
#99
i finally got around to doing this... still not dark yet, so i'll have to wait to see how it turns out...
Before:
After:
i also countersunk the hole on the outside to keep the spread as wide as possible (not sure if it'd actually make a difference, but whatever, took 10 sec to swap bits and give it a spin)
Before:
After:
#100
That's an interesting thought. I fully intend to do this mod, but was thinking of a plain, straight hole. But now that you mention it, I've got just the right bit to make it more workable.
#101
^i honestly dont know if it realistically does anything, but i figured it couldnt hurt. also looks a tad cleaner since it matches the countersunk bevel on the actual led itself.... not that anybody would ever see the part itself LOL
#102
I originally posted this about the tl but I traded my tl for a zdx and did it on my zdx too. My bro did it on mdx too. So I bet all acuras are the same if it has the led under the dash. I'm glad everyone likes the mod.
Steven Maslauskas Jr. (01-07-2020)
#104
Did this mod in no more than 10 minutes like everyone else. Definitely worth it, that light was killing me with how dim it was. I chose not to drill because 1) i wanted it bright anyway and 2) did not want to drill holes through just in case i ever wanted them back on and 3) tape worked perfectly regardless.
Did you, or anyone else, figure out the easiest and safest way to remove the over head light casing? I want to change the white to probably a blue LED color. I tried to remove the casing, starting at the two areas closest to the windshield but I got scared after i got it far enough to where i thought it should have come out with a little jingle and didn't. Didn't want to crack it. Also, if anyone knows what bulbs they are, please share. Thanks. I'm guessing 194 - 168 - 158 LEDs?
#105
Just discovered this old thread and think I'm going to give this mod a whirl. I quickly looked at the passenger panel last night in the dark and couldn't see how I remove it. I didn't just want to pull randomly on it and break any clips etc...
Any tips on how to remove the panels on the drive/passenger side to get to the footwell leds? I suspect it's as simple as yanking on it but thought I'd ask from those who have done it first!
#106
That knob/clip is located on the right upper corner if memory serves me correctly.
#108
Did this mod on the weekend and it was easy. I like it....
#109
is there anyone that lives in vancouver that could help me do this? I really want the underdash light, but im too scared to drill holes into the car... (never did anything yet myself) Do you guys think mod shops can do it?
#111
how did u get the picture shown so bright? i removed the cap, but when i take the picture, it looks completely dark
#112
I keep coming back to this thread hoping that someone will post that they called a friend who works at the shop that makes these covers for Acura, and that they've done a special run of clear versions for A-ziners. Wishful thinking...
#114
Hi Everyone
few people here were wondering about changing the color of the light. I wanted to post some pictures from my 2014 acura RLX which seems to have exact same lights but in amber/orange. At least the top cover which is clear plastic seems to be same... but not so sure about actual led base which seems littlebit slimmer. Anyway i think if anyone wants they could buy '14 RLX ones and you got yourself beautiful amber. Am posting some pictures here too
#117
ehh i like to keep it blue, my dome light emits a blue light so having it amber kinda throws off the look... but nice, you figured out some parts that are interchangeable.
