LED replacement lights
Old Jan 16, 2009 | 01:23 PM
parivera30's Avatar
How do you know which LED size to purchase for the 4G TL? For instance, on www.v-leds.com website, I see different 921 options for the backup lights. I'm not a mod. expert, first time doing any mods to my car so I'm a little confused.
Old Jan 21, 2009 | 01:53 PM
parivera30's Avatar
Would this kit work on the 4G TL? I want to replace DRL/High Beam bulbs.
-LEDS HID WHITE DRL UPGRADE KIT HB3 9005 6K IS250 IS350 IS-F
V-LEDS Part ID:9005_DRL_KIT# In Package2 - 9005 68 LED White Bulbs
2 - Inline DRL Modules
$79.99
Qty:
U.S. SHIPPING RATESFirst ItemEach
AdditionalBase Rate$3.79$.50USPS Priority$6.79$.50UPS Ground$6.79$.50UPS 2nd Day Air$18.79$.50UPS Standard Overnight$34.79$1.50Click here for international shipping rates.
LED DRL KIT
What an unbelievable difference these will make! SMT is the latest in LED design. High Output combined with even spread of light makes these bulbs perfect for any upgrade.
This kit is made specifically for vehicles using 9005 high beam bulbs as the Daytime Running Lights. If you purchase standard LED bulbs you will not get the output and look you desire. Our kit is the brightest 9005 DRL LED in the world. No others can compare! Great match for HIDs. Complete your exterior lighting with a High End, Luxury appearance. Kit includes 2 DRL modules and 2 LED bulbs.
This kit is intended for use as a Day Time Running light or for aesthetic purposes only. They are a great match for HID headlights but not intended to be used as a source of light to see by.
Clean N' Clear
Replace your ugly filament bulbs! LEDs and Housing are clear when lights are off.
Vivid Color
Replace your dull filament bulbs! Color comes alive with V-LEDS!
HID Look
Replace your ugly filament bulbs! V-LEDS give your ride that exotic look.
Old Jan 21, 2009 | 08:47 PM
bmode's Avatar
Man, from what I've seen so far, if your not experience with this, get some help with a pro. I popped off the housing on my driver side door courtesy light to see the bulb and it blew the box. Be careful, and keep us posted on your mods! I'm all for that upgrade by the way. I'd also like to get rid of the yellow parking lights,
Old Jan 21, 2009 | 10:39 PM
parivera30's Avatar
I'm tempted to do the mod, just not sure if that kit will work with the DRL/High Beam setup of the 4G. According to the website info on v-leds, it's a plug-and-play mod.
Old Jan 22, 2009 | 08:22 AM
CleanCL's Avatar
Terrible idea. Why would you want to replace your high beam with an LED? It gives off no light at all. I thought about it but quickly changed my mind.
Old Jan 22, 2009 | 08:55 AM
parivera30's Avatar
Do you recommend a bulb that would closely match the HID color for the DRL/High Beam? I just hate the color of the stock DRL's.
Old Jan 22, 2009 | 01:24 PM
CleanCL's Avatar
I hear these are good.
http://www.hoen-usa.com/
Old Jan 22, 2009 | 01:52 PM
parivera30's Avatar
Thanks. I might give these a go for my DRL's and Fog lights and use the LED's for the license plate, front turn signal, courtesy door, and revers lights.
Old Jan 22, 2009 | 03:09 PM
parivera30's Avatar
Would the 65W Hoen bulb damage the harness?
mada51589
Jan 9, 2025 04:40 PM
ellisd03tls
Sep 8, 2015 04:17 PM
drewdeezy03
Sep 3, 2015 08:04 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
