Lamin-x and "Crazing"
I’ve ordered a replacement passenger headlamp, and I’m tempted (given the cost of these things) to protect it with a Lamin-x film upon installation (along with the other headlamp and the two new fogs also going it). I had some concern about possible spiderweb cracks (or “crazing”, as I now understand they are sometimes called) from the film. I’ve read a couple of sources that blame film overlays for this.
I wrote to Lamin-x, and they say that crazing does occur, but their research suggests that it happens to both filmed and unfilmed headlight lenses. They stopped short of saying that the film had nothing to do with the crazing, but I believe that’s what they were implying. They used the example of a Ford Focus ST.
Has anyone experienced “crazing” on headlights protected by a film (or on an unprotected TL, for that matter)? Any other comments by anyone with film?
Also, for those who have filmed their fogs, have you gone with clear, or something else. I’m torn between yellow and clear, and am not sure what will look better on CBP.
a protected light is always going to be better than a unprotected.
lamin-x makes the best film protection on the market next to 3m..
and as we spoke about earlier on pm, its how you treat the film.. if you have your car running and the fog lights on while your stationary, then you will make the film heat up, and when you drive it will cool down too fast and it will start to crack over time. ive had mine for 3 years and now it barely starts to show signs of it burning but it can be peeled off and replaced with new one.
although i know peeling it off on glass fogs work, i am unsure about plastic lens fogs..
i just put my lamix on for the fogs thanks for the info on buring them out and usage ^^^^^i didnt think it would be that critical if the car was not in motion while the lights are on even with the heat they carry i thought the technology behind the lamix would have been designed with that in mind ...i will be more aware and not to use the fogs unless needed and only when in motion
According to the fine folks at Lamin-x (they're very good at answering inquiries), the film is fine...it's the adhesive that has problems with the heat.
real_mckoy (06-06-2014)
6G TLX-S
Can you post some pics ?
Looks like my wife's MDX fog/DRL housings have experienced "crazing". Lamin-x has been on it for past four years and it's started to discolor a bit. Upon close inspection, several horizontal cracks have appeared. When I ran HID fogs on old 03 TL with glass lens, it was okay. I am assuming it's combination of plastic lens plus higher temperature of halogen lights causing issues.
I've ordered the films, and will certainly put them on the fogs, but now I don't know what I'm going to do about the headlights. They're expensive to replace, and I don't want to leave them unprotected, but I also don't want to use a product that will cause the harm I'm trying to avoid. I had film on the headlights of my last car (not Lamin-x...3M I think), and the lights were fine after 9 years.
It's really difficult to keep a car nice in this city. Between the "sand" (in truth, road crush) they put down in the winter, and the idiots that improperly cart landscaping materials around in the summer (I've got two new chips in my windshield since starting this thread), it's a constant battle.
Ive had lamin x on my 4g since 2009 and the lamps have been perfect. I do cover my car and do not drive it often. Just turn 37K. Ive had lamin x on my miata since 2006 and no issue. I would never use it on fog lamps with factory bulbs. I have led bulbs in the fogs on my acura and no issue whatsoeer. However the fogs on my miata get VERY hot and the Lamin x burned in the center. Without modification I cannot use LEDs in the Miata.
Thanks farmdog (and everybody, even though you've all been of absoloutely no help, as I'm still left not knowing what to expect)
. What thickness did you have on the fogs, the 12 mil or the 40 mil? Also, also the film burned, are you able to remove it, or has this also damaged the light itself?
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
I have seen many threads complaining about Lamin-X causing headlight lens cracking or crazing. I personally think that there are two problems - the film thickness, and not leaving a clear space around the edge of the lens.
I have had 8-mil CLEAR BRA brand film on both headlights and fog lights for 5-years. No problems. However, the installer did tell me that they purposely leave a small 1/8 to 1/4 inche gap around the outside of the lens, to allow for heat dispersion - no idea if that is valid, just what he said.
I can see a couple of small (tiny) places where the film has been damaged, enough to show the actual lens. No damage to the lens. I assume it was pebbles.
On the other hand, last fall the car was in an accident, which damaged the headlight - cracked the shell but NOT THE LENS. Yes, the shell was completely broken, including one broken mounting tab, but the lens was not.
CLEAR BRA is used by my Acura dealer on new cars, and is why I used it. That brand is only available in a few mid-western states, at company endorsed installation places. You can search online I guess.
Be aware that there is a GM TSB which states that there are many chems which can cause healight lens crazing and cracking. Basically, anything other than water is a NO-NO. That includes car wax, although I have used Meguiar's M21 without problems.
Also, there is a caution against using a fender cover that drapes over the headlight, because often when working on a car, the headlights are on, and the heat will damage the headlight lens.
I'm still a bit undecided, even though my Lamin-x arrived two days ago, and the replacement fogs (and headlight) are going in today. I think I'll get an idea of how hot they run before making up my mind. I specifically got the yellow, with the intention that I intend to use the fogs as fogs, or in other rare circumstances where I need extra light. In the past, I've tended to run them all the time, which part of me thinks is tacky, or at least trying too hard, but I did it nonetheless. The other thing that concerns me is, again, the replacements have plastic lenses, which might react differently than what you experienced.
The headlights I'm going to hold off on for now.
Skier4lyfe303
10-19-2014 10:25 AM
sKAyEm
4G TL Photograph Gallery
38
02-17-2013 11:18 AM
