How much to install trunk spoiler?
Old Jun 27, 2015 | 09:33 AM
chasingthecool's Avatar
I was going to buy the trunk spoiler because I liked the way it made the car look, I didn't get tech package so the car didn't come with one. 425 for the spoiler already painted from the factory. How much and where should I go to install?
Old Jun 27, 2015 | 03:13 PM
BDoggPrelude's Avatar
You could just install it yourself. It's not rocket science. It probably comes with instructions and a template.
Old Jun 27, 2015 | 10:27 PM
Cooldude01's Avatar
DIY it's not that hard but you will need touch up paint to prevent rust from drilling holes. Good luck
Old Jun 29, 2015 | 02:05 PM
arpypat's Avatar
Shouldn't be too hard to install by yourself if you own a drill with some metal bits..
My Altima came w/o a spoiler and I installed a factory one myself. After I removed the liner from the trunk, there were small indents on the metal inside showing me where to drill, so I didn't even need to use a template.
The TL should be the same. I know they have indents on the insides of the bumpers showing where to drill holes for the lip kits, the trunk should be no different.
You can put some epoxy around the holes and foam between the spoiler and trunk to minimize the risk of rust also.
Goodluck!
Old Jun 29, 2015 | 03:44 PM
Crafty Veteran's Avatar
9th Gear
I called both dealerships in my area and one did it for $100 I believe. I purchased the part from a online dealership parts dept and the local dealer installed it.
Old Jun 29, 2015 | 04:44 PM
potmilkz's Avatar
a person without proper tools should not do it.. it is rather easy with proper tools....
putting an aftermarket exhaust on your car isnt rocket science but if you dont got a jack and 4 stands.. i wouldnt recommend doing it..
oyayjoe
Jan 1, 2019 10:17 PM
TLDude876
Dec 28, 2016 03:18 PM
BoricuaTL
Apr 8, 2016 01:08 PM
nanos
Nov 12, 2015 08:41 PM
EE4Life
Sep 11, 2015 10:13 PM
