help w 2010 tl!
help w 2010 tl!
hi guys!
sothe issue im havin is i recently bought a 2010 tl brand new w 10 miles.......i know have 700 miles and recently went on the highway n feel the car vibrating and shaking at higher speeds then 60mph.....went to dealer they told me the tire pressure was low......still same issue...went on my own checked wheel alignment and everythin perfect.!wha can be the issue?
also if im sitting in the car not even moving and turning steering wheel left and right i hear a grinding noise inside the car from sterring column????
Sounds like tire balance or tire flat-spotting.
If you're hearing a "whirring" noise when you turn the steering wheel, that's normal. It's the electric steering.
But grinding is not normal.
ya when i go over 65 i feel grinding /vibrations in the gas pedal and steering wheel......its very annoying esp that the car is brand new w only 700 miles now....i took it to them and they said its the tire pressure but its still doing it....maybe the tires? i dont know what to do anymore..........
honestly i just dont know what to tell them anymore.....how to describe he issue.....i feel like they take the car wash it and tell me they fixed whatever issues i bring to them.........can it be tires? should i tell them to give me a diff set of tires for a week to test it ?
Have them come on a test run with you, it's better to have a tech or dealer employee actually drive the vehicle themselves but with you and point out exactly what it is you feel happening with the car. I thought that was standard procedure for most dealers for something like this anyway. If they won't do that try another dealer, worst case call Acura corporate, open a case and you see how fast they get on it.
search tire balance/ing as someone else here in AZ had a similar issue.
I'm having the exact same problems. Still in the process of getting it fixed. Try the dealer one more time, and if that doesn't help, give acura client services a call. I've had my tires balanced 5 times, and my tires replaced as well. Still problems.
Here is the problem. Most cars come with a good 4 sets of tire. But, the reason is tires made from rubber. and When they had to stay on the same position for a long time, the shape of tires seem to change a bit. Some of them, when you buy your car, and start driving it, those tires will soon come back to normal shape due to hot road and weather. BUT, some of them (unfortunately) will keep the weird shapes forever (means defective tires-Suckers those manufacturers) So as long as your car is a new car, then just ask dealer to replace 4 new ones.
Secondly, ask them this one, I learn this from my friend tire shop and I only trust him to do the balance for my TL. ASK those damn dealer suckers should change the caliper of balance machine before they balance your car. That's the big point.
Because when the balance machine has been used for a long time without replacing caliper, it seems not to accurate anymore. Believe me! My friend own the Bridgestones shop and he is in business for 10 years.
ya, then thing should be ok.
but:
if your car is vibrate during driving on the freeway, it's the balance.
but, if it only vibrate when you brake, it's the brake issues.
resurface should be a solution. but, will decrease your brake rotors life.
change new brake disks??? too good but costly!
so, they all depend on your decisions.
I got my car fixed because I am lucky.
Good luck to you my friend
but:
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
TLguy42
09-26-2015 11:27 AM
