Front Turn Signal Light question
I want to make turn signal bulb into a dedicated turn signal rather than running light so it only comes on when I put signal on.
Can anyone give me some tips on it?
Also, if I just want to change the color, will replacing the bulb solve the problem or is there any other mods I need to do?
Does anyone have a manual on how to replace the bulb for turn signal light?
Thank you guys
Thank you guys
I'll tell you how to make it just a turn signal.
Take out the bulb.
Put a piece of electrical tape on one of the black contacts on the bottom of the bulb.
Install the bulb.
Test that turn signal works.
If it does, you are finished.
If it does not, put the electrical tape on the other contact.
Test again.
Take out the bulb.
Install the bulb.
Test again.
