Engine mounts
Old Aug 19, 2021 | 11:20 PM
CoreyP's Avatar
Engine mounts
Anyone here replace their engine mounts? I'm getting a good amount of vibration in the car at idle and I think the engine mounts are worn out? Is this common with this car? The front engine mount is not smooth on top, it doesn't look torn but it is wrinkly for a better description? The engine doesn't jump up when I hit the gas but seem to be getting more engine vibration at idle then I did in the past, wondering what is doing it? Engine is running fine and I don't think there is a problem there which means the mounts might be the problem?
Old Aug 20, 2021 | 05:26 AM
to truly know if your mounts are bad, you need to pull the covers and look at them.
but otherwise; yes, the J-series engine loves to eat motor mounts.
if you can afford the OEM ones, buy them..
if you want more affordable options, go to rockauto and buy the OEM-like mounts.
Old Aug 22, 2021 | 11:03 PM
CoreyP's Avatar
Two are cracked for sure, that probably causes the vibration problem. Too hot to fix that right now, maybe in a few weeks or so.
vladkarnafel
Mar 21, 2012 09:15 AM
ironsurfer129
Sep 12, 2011 07:15 PM
chilifrost
Mar 21, 2006 11:38 AM
