Engine mounts
Engine mounts
Anyone here replace their engine mounts? I'm getting a good amount of vibration in the car at idle and I think the engine mounts are worn out? Is this common with this car? The front engine mount is not smooth on top, it doesn't look torn but it is wrinkly for a better description? The engine doesn't jump up when I hit the gas but seem to be getting more engine vibration at idle then I did in the past, wondering what is doing it? Engine is running fine and I don't think there is a problem there which means the mounts might be the problem?
to truly know if your mounts are bad, you need to pull the covers and look at them.
but otherwise; yes, the J-series engine loves to eat motor mounts.
if you can afford the OEM ones, buy them..
if you want more affordable options, go to rockauto and buy the OEM-like mounts.
