DRL Replacement
Old Jul 13, 2009 | 10:14 PM
djavenger's Avatar
DRL Replacement
Has anyone been successful in replacing the DRLs with anything that looks better???
Old Jul 14, 2009 | 12:25 AM
BLACKURA_NY's Avatar
I have car ADD
thats tough, because the DRL is also your high beam... you dont want to put an LED in there, because it will never be bright enough when you need it , on a dark road
i think personally, the best bet, is like a Nokya 2500K 9005 Halogen bulb... yellow tint, and still bright enough when needed... i know thats what im putting in mine
Old Jul 14, 2009 | 06:54 AM
Haelous's Avatar
I was hoping to get a bulb that would appear white, but since it's something like 30% highbeam I'm unsure if there is a bulb that would do this but not appear blue when you turned on the highbeams.
Blackura's suggestion isn't bad, since I imagine those would give off a quality yellow, as opposed to the dim white of the stock bulbs.
Old Jul 14, 2009 | 08:26 AM
CleanCL's Avatar
I put in LEDs, I never use my high beams.
Old Jul 28, 2009 | 09:26 PM
Bearcat94's Avatar
AZ Community Team
Moved:
https://acurazine.com/forums/announc...php?f=295&a=24
Old Jul 29, 2009 | 03:01 PM
evocative's Avatar
Link to the ones you bought?
Old Jul 30, 2009 | 08:04 AM
CleanCL's Avatar
I got the 9005 18 LED SMT from here:
http://autolumination.com/headlights.htm
Overall during the day time, it provides a pure white. I went with them because of the price, but I'm going to try these 68 LED ones next:
http://www.v-leds.com/Exterior-LED/D...79223-1-2.html
Old Jul 30, 2009 | 08:11 AM
PetesTL's Avatar
Just curious, is there anything illegal with using these as DRL replacements?
BTW, the v-leds are awesome....I bought some for my rear license plate lights and the light output and color was fantastic!
Old Jul 30, 2009 | 11:17 AM
Haelous's Avatar
You guys may want to check out this thread from the RDX section: https://acurazine.com/forums/showthr...=681668&page=2
The Hoen Xenonmatch Plus 9005 looks like a good choice with its color while being used as a DRL and the 9005 is 55W like the stock bulb so there's no risk.
Just another bulb to consider if you actually want to use your high beams at some point, while if you put in LEDs they're totally useless.
Old Jul 30, 2009 | 03:06 PM
CleanCL's Avatar
Hm.. that's impressive. I read about Hoen, but I figured any regular bulb would look yellowish given the lower voltage. Maybe I will give them a try.
Old Jul 30, 2009 | 03:22 PM
PetesTL's Avatar
I have Hoen fogs....color is slightly purple-ish......so match isn't that good with the main HID's......but still better than stock. (I think I should've gone with the V-Leds for fogs).
Old Jul 31, 2009 | 08:35 PM
benzboy429's Avatar
i just took out the fuse for the drl and now they dont go on and the high beams still work fine along with all auto headlight functions
Old Aug 2, 2009 | 04:24 PM
CleanCL's Avatar
Do you get a DRL Malfunction error on the MID display?
Old Aug 2, 2009 | 11:29 PM
benzboy429's Avatar
nope
Old Aug 22, 2009 | 09:52 PM
NoelMarley's Avatar
Thanks for the info CL. I just purchased the 68 LED lights. I'll post pics when I install them. I don't ever use highbeams either.
Old Aug 22, 2009 | 10:42 PM
PetesTL's Avatar
I had the 68 LED's....kept on giving me DRL error messages.(most likely due to the low voltage draw on the LED's). The color looked good but the output is pretty dim, esp. during daylight. I got sick of the error messages and replaced them with the Hoen's.
Old Aug 23, 2009 | 01:28 AM
NoelMarley's Avatar
Sh!t... Thanks. The error message will bug me too. Going with Hoens.
niray9
Dec 8, 2015 07:34 PM
sockr1
Oct 1, 2015 01:31 AM
JnC
Sep 11, 2015 06:06 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
