DRL/high beam adjustments
Old Jul 29, 2011 | 09:35 PM
01stang's Avatar
Is there adjustment screws ,for the high beams, I found the low beams one but no luck with the drl, I change bulbs and it a tad higher than stock need to lower them a tad
Old Jul 30, 2011 | 05:08 PM
01stang's Avatar
Some ones gotta know
Old Jul 31, 2011 | 06:10 AM
JnC's Avatar
JnC
Former Sponsor
High beam/DRL is molded right into a bracket that holds the low beam projector in place. You can only adjust the beam on vertical axis i.e. up and down and not on horizontal axis. If you adjust the low beam you will actually also be adjusting the hi bead/DRL.
Old Aug 9, 2011 | 08:14 PM
01stang's Avatar
Thanks for the reply, I'm gonna hit u up soon to have my headlight blacked out, just figuring out which route I want to do my car first
Mike734
Dec 10, 2021 01:25 PM
rockyboy
Sep 29, 2015 12:05 AM
ceb
ILX
Sep 27, 2015 10:56 AM
lowgrowl
Sep 26, 2015 05:18 PM
flybyglass
Sep 24, 2015 01:12 PM
