DRL fuse.....
DRL fuse.....
Hi I own a 2010 TL- FWD and is there way I can stop drl when I drive..and how can I fine where is fuse and if I do pull out fuse for drl will I get error sign? And will it mess up anything and out will the highbeams work..? Thmx a lot everyone who answer.
Love Guru
Hey OP,
Yes, the high beam will work and you will get no error code. I had it removed through out the spring and summer. Just plugged the fuse back in once the days started getting shorter, as a safety precaution.
Hope this helps.
Hope this helps.
so our alternatives for "modding" our DRLs are to either put in an LED to make it look "cooler", but then we DO lose our high beams... or just pull this fuse.. and we no longer have DRLs..but we maintain the high beams...
I think I will go the latter route.. I like that idea.
but I still need to do switchbacks in my turn signals...
What is the price of vanity, anyways?
I suppose it depend on where you live. In certain area and condition it would be helpful to have drl. I live in California and the weather is mostly sunny year round and visibility is excellent. If other drivers can't see me unless I've drl on then they shouldn't be on the road. The other day I had someone high beam me during daytime because they thought my high beam were on. I'll be pulling the fuse this weekend.
I'm in a northern climate. DRL's are necessary. Even in, as you point out, sunny conditions, and perhaps especially so, DRL's are important. If someone is driving toward you and the sun is behind you, low on the horizon, DRL's are the only way you're being seen.
Finally, here (and I recognize it might not be everywhere) DRL's are law; disable them and you're taking your chances, as any accident will mean at least a portion of liability will shift back to you.
I can't account for another driver flashing you thinking your highbeams were on, though of course they were...you likely know the DRL's are simply highbeams at reduced power. During the day, it shouldn't have been an issue, and at night, your car should have defaulted to lows. Either way, my position would be TFB for the other driver...some are just too sensitive.
DRLs are outdated and their "safety" benefit has been disproven. All studies that promote DRLs are outdated and from countries with horrible street lighting (30 years ago). The only reason we have DRLs is because people refuse to turn their low beams on during dangerous driving conditions. When visibility is compromised, just turn your low beam on. Why leave safety up to a feature that provides only half the voltage.
They are required by law in Canada, not the US.
If they were meant to "throw light", as opposed to simply making the vehicle more visible, then makers such as Audi, and now Ford, Kia, Mercedes, etc., wouldn't be using leds, since the technology isn't there to make leds illuminate sufficient area. They're easy to see though.
But again, you're correct that in areas of low light, your low beams will do a much better job. And if your TL is working the way it should, the vehicle should take care of that for you. The DRL's are for when it's bright outside.
You're likely correct when you say that DRL's are only mandatory in Canada, and not the US. My point was, unless there's a good reason to do so, why disable a safety feature? My horn may never save me from a collision, but without a reason to disconnect it, it would be stupid to pull that fuse.
You can simply Wikipedia daytime running lights to find your evidence regarding statistical data. I'm typing on my phone so if you're truly curious, you can look yourself.
By dangerous driving conditions and compromised visibility, I meant during the day time (I. E., rain, snow, fog, and winter months where there is limited sunlight). Your interpretation is that having a light on during a clear and bright day will improve safety by making you more noticeable, which has been disproven by recent studies. My point (backed by data you can google) is that if you are driving and the visibility of you or others are slightly compromised (during the daytime), then it would benefit you even more by turning your low beams on, which many do not do. Whether they're lazy or don't care is not apart of this discussion.
Hi Inder, just wondering why you wanted to do this? Saw Ken say b/c someone may have thought he had his high beams on. Just seems a little weird, but to each their own. Won't argue reason, just wondering is all. Thanks!
I grew up with sunlight, light off. I had no trouble with saftey. I don't like the way a car looks with lights on in the daytime. Looks wimpy to me. So... I removed the fuse. None of my cars have DLR and I hope I can keep it that way.
Cool. Yeah when I said weird I didn't mean it by implying that you did it b/c of the guy flashing you. I meant it seems a little weird to bother disconnecting them. I just looked at mine today. Never really took the time to look at it with the lights on. I guess it's just a preference.
DRLs are pretty useless if you are the type to turn on low beams in the rain or bad weather...
They are the precursor to the new LED 'twinkle' lights which are the newest ricer fad to touch the luxury auto markets.
I'm considering pulling the fuse as well. Not all cars have DRLs, especially older ones, and I don't feel they are much less safer and I don't see people rushing to install them on their cars. My previous car (2002 Infiinity i35) did not have DRLs and I never felt unsafe.
That being said the moment someone figures out a way to put LEDs on the DRLs and still have high-beams I'll put them on...
Wouldn't mine having leds instead of the high as drl. Would be easier to just have leds with a switch so you can turn it on/off or wire it so they come on with ignition.
6G TLX-S
Yes, the Audi can change the DRL setting via the MMI menu.
Hey sprry everyone for very late reply but I wanted to turn drl off coz of I got my headlights done by aktl05 and I installed halo and they turn on when my car turn on so I was thinking to turn off the yellow light...sorry for late reply and thnx for ur replys..
That's like saying, "so all cars prior to seatbelts becoming mandatory in the 70's are dangerous?" or "so all cars without airbags are dangerous?".
Not having a safety feature which is available on other cars doesn't make a vehicle inherently dangerous. But then, you knew that...you were trying to make a point.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
