DRL alignment issues
Old Aug 5, 2011 | 08:39 AM
jaydm98's Avatar
I went ahead and put my stock OEM 9005 bulbs back in for the DRL/High beam. But for some reason the alignment looks off. When reflecting the DRL light/highbeam against the wall the passenger side looks higher than the driver side. I look inside the housing in the passenger side the bulb looks like its pointing down. And on the drive side the bulb looks like its straight in. I checked to see if they were screwed in correctly and they seem like they are. Has anyone else had this issue? Thanks in advance.
Old Aug 5, 2011 | 09:26 AM
Takehold66's Avatar
sounds like the bulb did not seat correctly when you installed it. try removing it and reinstalling it.
Old Aug 5, 2011 | 09:42 AM
jaydm98's Avatar
I tried that it and it feels like its sitting right because when I put the bulb in and twist the bulb and housing locks into place. And it seems like it can only sit one way. I will try again and hopefully I can have it sit another way so that the bulb is straight. Thanks takehold66
Old Aug 6, 2011 | 09:26 PM
Mr Marco's Avatar
Have one car with this issue. It's not that bad, and I'm too lazy to fix it.
Old Aug 7, 2011 | 10:46 AM
jaydm98's Avatar
I see. I eventually got it to sit right and they are both even now.
Old Aug 7, 2011 | 07:37 PM
pickler's Avatar
i have the same problem with my rdx, how did you fix it? btw on my rdx, the oem bulb is brighter than anything else i have tried.
Old Aug 7, 2011 | 08:18 PM
jaydm98's Avatar
All I did was make sure the bulb sat right in the housing and looked center in the headlight instead of pointing down. Then I twisted clockwise.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
TxRzrBk
Sep 17, 2015 01:07 PM
JnC
Sep 11, 2015 06:06 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
