Clutch recommendations?
What's up fam!
My TL is starting to engage really high on the clutch stroke, and while it may be adjustable, I'm starting to wonder about good brands/models for replacing the clutch.
Any good recommendations?
OEM Exedy clutch kit.
https://shop.exedyusa.com/exedy-oem/...i-2295578.aspx
https://www.lmperformance.com/857566...v6-37-awd.html
https://www.rockauto.com/en/catalog/...lutch+kit,1993
If you buy the parts from a dealer instead (like acuraoemparts.com = Delray Acura in Florida), make sure you buy all of the components of the clutch kit: friction disk (22200-R4N-003), pressure plate (22300-R4N-003), pilot bearing (91006-RK2-003), and throwout bearing (22810-PPT-003). The kits come with the alignment tool, but you won't need it if you're taking it somewhere to have it replaced. Even if you buy the parts from Acura, they're manufactured by and labeled as Exedy anyway.
