Brake pads
Brake pads
Good morning
i checked my front brake pads, and are due for replacement. the rotors are in really good condition with lots of meet left on them
what brand would you guys recommend for the TL?
Cheers,
Cheers,
Budget is not issue. No need for race pads. Just asking what most owners use. Yes autozone is 3 blocks away but I'm not happy with reybestos or what ever. I found racestop on Amazon $36 for front pads . I think they were carbon ceramic pads. I'll share link
https://www.amazon.com/dp/B00JGRPO4U/ref=cm_sw_r_cp_apa_glt_fabc_SFK3SRKGZQ4MV1T7BTGV
Is there something you felt that the original pads were lacking? If so, then what? Pads all do different things well. Let us know what you're looking for so we can make a sensible recommendation.
If you didn't feel anything lacking from the originals...then just buy the OEM pads from a dealer. The factory pad is the best all-around pad. Which is why Acura painstakingly chose them and then put them on every TL they made.
justnspace (04-11-2021)
again, what are your requirements in a pad?
why use the motul 5.1 if race equipment is not required???
what is your goal?
again, if you need pads right now...there's an autozone right down the street from you.. go pick up some pads.
if you dont mind waiting and want OEM....try the Acura/Honda dealers.
what is it you want in a pad?????
what is your goal?
I installed the posi quiet brake pads with stop tech slotted rotors because my OEM ones were warped at 30K miles. Got a gerat combo deal on autoanything.com. Posi Quiet pads are quiet with no squeaking but produce a lot of brake dust. I mean A LOT of brake dust. The wheels turned all brown on the inside and the calipers looked like they had rusted from said brake dust. If you do regular wheel cleanings its a great pad. Still going strong with lots of thickness left 30K miles later. Make sure you relube the guide pins and apply permatex brake lube to the back of the pads aswell to limit the noises
factory pads are your best bet; almost no noise or dust
The car gets dirty, and so do the wheels. Safety/performance>dust anyday. I switched to semi metallics and they perform amazing compared to ceramics and organics. They clean right off during a car wash, and I wash my car only a few times a year.
csmeance (04-19-2021)
I go with pads that work well. I consider dust way down the line of priorities.
Belated, I actually use Motil 5,1 too. Was a better price and I liked the EBC yellowstuff however I wanted zero dust, and squeaks so Akebono ASP for the front Akebono ACT on the back. Didnt make ASP or ACT for the rear. Totally silent, near zero dust and slight upgrade vs OEM.
