Blank key.
Blank key.
I lost the key that goes with the fob...
Does anyone know where to get one at a decent price...?
Went to Erin Mills Acura today and they want $130 for the blank plus $25 for cutting the new key.....that's $175 all in....
WTF is wrong with them...$175 for a piece of plastic and some cheap metal.... f@#$%$g a@#$%$#s !!!!
Anyone?
Thanks for any info....
Anyone?
They have you by the "short and curlies". I think (and I'm sure I'll be corrected if I'm wrong) that includes programing the key into the car computer.
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
If you're referring to the keyless entry key (#8), Delray Acura has them for $23.
If you're referring to the non-keyless entry key + transmitter (#7), they're $86.
arek1200 (12-24-2014)
I don't see # 8 listed in the diagram....Am I missing something here...?
6G TLX-S
The contents inside the rectangular box at the bottom left corner of the diagram is item #8.
Here is the stuff for the keyless entry keys.
PN: 35113-TK4-A50 KEY, EMERGENCY (BLANK)
arek1200 (12-25-2014)
Oh, and the MSRP price for the brand new keyfob is $122.97 (PN: 72147-TK4-A71 FOB ASSY., ENTRY KEY), so your local stealership is probably trying to charge you for the whole damn thing rather than just the emergency key...
Thanks a lot for your help!
Actually my local STEALERSHIP wants $130 for the emergency blank + 25 to cut it (they send it out to some shop to have it done) and another $130 for the fob plus programing and I would have to make a service appointment to have it synchronised with the car...so the grand total for the complete unit would be around $322
I asked why so much for an emergency key...? and the idiot behind the counter said ...oh its got a chip in it and it needs to be programmed and laser cut....I told him there is no chip in the blank emergency key...he kept telling me that there is...
....and why do they call it a"laser cut key"...the last thing they use to cut it is a laser....all the blanks are milled....not laser cut....
very disappointed customer here..
will check with another stealership if I get the same BS.....
6G TLX-S
That link was referred to the base model trim TL, that has the metal key ignition system.
You'll have to back out of the vehicle selection choice, and reselect either the Tech trim or Advance trim TL, that has the key fob entry system.
2 NEW Replacement Uncut Prox Smart Remote Emergency CAR KEY Blade Blank Insert A | eBay
I contacted the seller and was told ...manufactured to oem specifications....they would probably work as good as oem products...
It does get even better...I called Acura of Oakville hoping they would have "better" price for that blank...I WAS TOLD ITS $160.0 !!!!!!!!!!!
WTF?????!!!!!!! plus $25 to cut it ...and of course programing ...
what f!@#$%g programing ???!!!! there is no chip in the blank!!!!
Why are they keep telling me they need to program the blank!!!!???
Damn fools... are they even understanding which key you're referring to? Not a blank entry key with the transponder... not a blank valet key... ask them to pull out the keyless entry emergency key (give them the part number), then tell them get in the car and try to figure out how to turn it on with that key. If they can't figure it out, it doesn't have an immobilizer chip to be programmed lol.
And I just looked through both the owners manual and the Haynes service manual with neither mentioning anything about the keyless emergency key having any association with the immobilizer unit.
It just makes you wonder if they have idiots like that working on our cars....
6G TLX-S
Try asking another dealership(s) that has some much-more smarter staffs.
jdmaszfcuk
10-19-2015 12:31 AM
kixo
09-25-2015 03:07 PM
