Best Halogen Bulbs
Best Halogen Bulbs
Looking for the best halogen bulbs out there that output the brightest for my DRL/High Beam and Fog lights.
I currently have Eurolite high beams and they're useless. I also have the eurolite yellow fogs and they do work well but I know there's stuff better out there. Trying to avoid any HID setup.
So looking for the best bright white for DRL/High and best yellow for fogs. What do you guys suggest? I've heard of Nokya (had them on my previous vehicle) but found they gave out every year to year and a half.
I'm just worried the lens will burn, but if I can get the yellow effect with an HID setup then I might go that route. It's just more of an expensive way to do it since a good branded HID system is roughly $150. I wouldn't cheap out on a DDMTuning setup.
From my understanding, the stock bulb is 35w meaning that the housing and lens should withstand a 35w HID bulb as well since heat production should be similar. Can anyone confirm this?
Yeah I'm just trying to figure out which one gets hotter and at what temperature. I believe Osram Xenon bulb base gets to 240C and the bulb glass goes up to 740C. Not sure if this is lower than a halogen bulb. Apparently the filament of a halogen bulb gets hotter than the arc of an HID bulb does.
I've always used Hoen in my cars...nice bulbs and life.
http://www.hoen-usa.com/index.htm
I have the H11 55w xenonmatch...great bulb to match the stock HID.
Here is the kink to the yellow endurance..http://www.hoen-usa.com/fog.htm
https://www.2checkout.com/checkout/purchase
ripit
09-26-2015 06:19 PM
