Beeping noises
Beeping noises
Anyone find all the warning beeps on the tl as annoying as i do. I'd love to disable the screeching noises i get when i walk away from the car when it's running. At least acura should have given us the option of lowering the volume of these sounds.
Well it'snot as annoying as the voice in the TSX, and they want to make sure you know that you have the key and are walking away from the vehicle.
I thought there was a way to lower the volume at least. I'll need to re-check the manual.
I think that you can adjust the volume on the MID...
Let me know if you find the way to reduce or kill the beep when walking away with the car running. I figure one can always put a relay tied to ignition so it disconnects the beeper when running, but will enable the beeper for the regular door lock beep (assuming it's the same beeper as I think it's from the rear of the car). Pretty simple mod..
annoying a small number of TL owners is much better than having idiots leaving the car on overnight and possibly killing themselves in the process..
much like the seat belt chime, safety first.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
