Battery Tender leads
Old Mar 13, 2013 | 08:43 AM
Shoot2Thrill's Avatar
Walk the walk
For those who have hooked up one to the 4G how did you make the connection to the negative how did you run the leads outside the car?
Old Mar 13, 2013 | 10:15 AM
Treblig's Avatar
During my last dealer service visit I had them connect the leads for me. I just tuck them into the small depression in the plastic covers. I will provide a pic when the chance presents itself.
Old Mar 13, 2013 | 10:39 AM
Walk the walk
Do you leave the hood open?
Old Mar 13, 2013 | 11:19 AM
Edward'TLS's Avatar
6G TLX-S
I follow the info inside the user's manual and clip the negative wire onto the engine hanger, located on the left side of the engine block.
Then leave the hood open just a crack to let the 2 connection wires out and not getting them crushed.
See below :
Originally Posted by Acura 2012 TL User's Manaul
5. Connect the second jumper cable
to the negative ( ) terminal on
the booster battery. Connect the
other end to the engine hanger as
shown. Do not connect this jumper
cable to any other part of the
engine.
Old Mar 13, 2013 | 12:29 PM
Treblig's Avatar
I close the hood but don't latch it.
Old Mar 13, 2013 | 02:44 PM
weather's Avatar
^^^ I do the same thing, i just don't latch the hood. There is a little bolt/screw that I connect my negative terminal onto...if you need to see, let me know and I can try and post a picture.
Old Mar 13, 2013 | 03:53 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
i connected both leads to the battery. leave the hood closed just enough to catch the latch but not all the way closed.
Old Mar 13, 2013 | 03:57 PM
djtanveer's Avatar
Just curious. Whats the purpose of the battery tender?
Old Mar 13, 2013 | 04:00 PM
Treblig's Avatar
Keeps the battery from draining when the car is stored or not driven for an extended period of time.
Old Mar 13, 2013 | 04:02 PM
djtanveer's Avatar
Oh OK. thanks. I probably wouldnt need that since I Daily my car. good to know though.
Old Mar 13, 2013 | 05:05 PM
Domm's Avatar
It's also useful for areas with extremely cold climates when it takes more output to crank the engine. You probably never need it with the bay area weather.
Old Mar 13, 2013 | 07:43 PM
Treblig's Avatar
Here is my setup, for those still interested:
Old Mar 13, 2013 | 07:53 PM
ExGMan's Avatar
I always connect the Optimate4 to Mrs. ExGMan's 2007 5-Series BMW if it won't be driven for 4 days or more. I left my 4th-Gen TL for two weeks w/o an Optimate. No issues at all.
I have found that I can go out into the garage in the middle of the night and the BMW is making whirring noises just sitting there. The TL is dead silent.
Old Mar 27, 2013 | 09:21 PM
Walk the walk
The issue with with using Acura's way to hook up the "Battery Tender Leads" is the leads and or clamps does not have that much travel. I ended up using the battery terminals. I clipped the lead washers to be a C ring just sufficient to clear the 10 mm bolts. This way I did not have to remove the nuts which have a locking provision to avoid lose. The wire routed nicely out next to the rubber hood stop cutout. Seems there is a small arch near the hole perfect for the wire. The cars are garaged so I decided to leave the hood up. This way it is not as likely to be inadvertently driven away while hooked up. Figure it wont hurt hood strut life either because the pressure in the cylinder is at the lowest level and seal leakage will be lower. Further, this is how they are stored on the shelf.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
