Anyone use Liqui Moly?
I've been using Castrol Edge Extended Performance but can get a heavy discount on Liqui Moly thru my job. Anyone have any experience with this oil?
![](https://cimg2.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/15666826583462114601019122568410_bc8f0fb764334c2801b7d6c27c4b0444525bf1e0.jpg)
My current oil and filter of choice.
I'm glad I work for a large European car parts distributor that I'm able to get it for cheap. Gonna use the last jug of Castrol I have.
Latent car nut
Received 2,008 Likes
Folks, discussing which oil falls within the category of "Overthinking things"; as I have said many times on this forum, oil is like religion, use whichever brand and product line you worship; assuming you change your oil on a relatively regular basis, the oil will not make a tinker's damn worth of difference in the life of your engine.
If you can get a heavy discount then go for it. I've heard good things about Liqui Moly over on bobistheoilguy forums. Can't say if it's any better than any other oil but I heard that BMW and Mercedes (the ones built in Germany) do their initial fill with it, so it can't be half bad.
If the discount is significant and worth it, then go for it! Oil is oil for most folks. Unless you are doing oil changes 1x a year or doing a lot of driving you'll be fine with either. I've been using M1 Gold Cap EP with either a M1 filter, Honda filter and now the Fram ultra filter with good results. Fram Ultra shows a bit more filtration down to 20 microns @ 99% vs the M1 that does up to 30 microns at 99%. Also trying Pennzoil Ultra Plat. Oil in the MDX to see how it holds up to the higher side loads of the 3.7L vs the 3.2/3.5.
Heck I was happy to see amazon selling Pennzoil Ultra Plat 5w-20 for 17.99 one day so I bought 6. I usually paid 35+ per. Granted the Amzoil filter is my goto w/ price tag, however the Purolator Boss filter is a new alt for me in a pinch.
Redline / Amzoil are the alt oils. There is my oil religion
Kinuto (09-01-2019)
sergio2047
01-29-2009 11:50 AM
