Anyone install a trailer hitch?
There were only a couple previous posts regarding the installation of a trailer hitch. I'm wondering if anyone has installed one and has some pics available. I'm looking at this option for a bike rack.
I had one installed. Works great. Only issue is that you can't (I am told) put more than two bikes on the rack, or it will be too heavy. But from a looks standpoint, it is not at all unsightly. Send me an email at jnhyman@hotmail.com and I will send you a photo.
J4 Sharks Pics
It would be nice to see the entire back to see how it looks with the tailpipes...etc
I'd also question the 2 bikes. I would think that a hitch like that could pull at least 500lbs or more.
(not a 4th gen but if it can handle the weight of this, yours can handle more than 2 bikes)
TLs are not approved or rated for towing. (3 or 4 G)
The owner's manual cautions against it.
Because of warranty issues and because even a loaded trunk will cause rapid wear of the rear tires, it's not a good idea.
The rear suspension is tuned for handling and has features to compensate for FWD understeer. These methods work good for handling but a load on the back throws the rear tires way out of alignment. It is a known issue for 3G especially.
This may be why the installer said no more than two bikes. I recommend you check with the dealer before you install the hitch and ask them if it will negatively impact your warranty on a) the vehicle, or b) the tires.
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
