Anyone else have these small issues?
Before the warranty is up on my TL, I'm inclined to have a couple of things looked at, but I thought I'd canvas the mambers here and see if the issues I'm having (all minor) are common or not.
First, on cold days, I notice I get some fogging in the raised stop lamp housing. You can see it in a picture I added to my album a while back.
On hot days, when the sun has really heated it up, the trunk lid creaks terribly (on opening and closing). Almost to the point of having a bit of a "clicking".
My windshield has a bit of a distortion when looking towards the the front passenger fender (not "at" the fender, but in that general direction). Almost like the glass is warped or "coke-bottled" a bit there.
All admittedly minor issues, but can be annoying. The windshield, for instance, seems like it could be ignored, but every morning when I do the "right-hand corkscrew" into my parkade, I can't help but notice it on every turn.
Is this unique to my ride, or have others seen these sorts of things?
My trunk also creaks - dealership should be able to fix it w/o charging you, as they did for my back window that was making noises when I would pull it up.
I have a passenger turn signal housing that needs to be replaced - there's a crack in it somewhere, because condensation is building up in there, and I'm sure it's going to ruin the bulb eventually.
My outside temp sensor is also out of whack. It's not correctly reading the temp, which is only slightly irritating, but I'm sure that will not be covered under a warranty ( neither will the turn signal ).
How much do these "minor" issues annoy you? Would you pay your insurance deductible to replace the windshield? And what happens if you get a replacement windsheild that's even worse (I've personally had that happen on a previous vehicle)? Then you have a whole new set of problems.
Personally, I'd get the lamp housing checked out, and see if the dealership can do a quick fix on the creaky trunk. The windsheild seems like it would be a large expenditure, and possibly not worth it, because Murphy's law will probably throw a rock your way and crack your new one
snorf
11-04-2019 07:44 AM
mugen_kid
11-13-2015 11:38 PM
CheeseyPoofs McNut
10-11-2015 12:25 PM
Billu99tl
09-13-2015 12:30 PM
