Anyone with an aftermarket alarm and SmartKey??
Question on functionality... If you lock your car with your aftermarket alarm remote or OEM remote and then walk up to the car with the smart key in your pocket and grab the handle to the door, does it disarm the alarm when it unlocks the door?
i would think you would have to disable the factory alarm to put an after market alarm on there.. this will disable the function of having the door handle unlock when touched.
your question seems confusing.
with an oem remote, once you put your hands on the door handle, your car disarms and unlocks.
really not sure what you are asking as far as how OEM function works.
-_____-.... you just answered your own question..
i dont think you funny understand what i am saying.
with aftermarket, it maybe different. not sure. but with oem, you keep your keyless function.
With my OEM remote I can unlock and lock vehicle (this also arms and disarms the aftermarket alarm)
The only problem I have is when i walk up to the car and put my hand on the door handle, the door unlocks, but it doesn't disarm the aftermarket alarm like the OEM remote does.
A good aftermarket alarm makes sense if you drive a 1969 Camaro RS, but it's a complete waste of money on a TL.
That was a pointless post. I use the feature to notify me if my car is hit in the parking lot.
ditto, unnecessary money spent. there is absolutely nothing for a thief to take in your tl besides your own belongings and your wheels.
like i said before, the aftermarket and your oem isnt reading with eachother. your door handle tells the car to unlock and disarm the OEM alarm only. not your aftermarket one.
potmilkz (04-26-2012)
6G TLX-S
Simple answer. OEM and aftermarket alarms don't mix.
A proper impact sensor would have saved the side window on my RDX from being bashed in by a theif looking for my laptop. I had thought about getting a paging alarm for just that reason. However the last time someone hit the TL it was in the long term airpark while we were on Oahu. So the functionality of that kind of system is mixed.
Just an FYI guys, my alarm/starter is installed (installed myself) and everything is working. This was purely a thread to ask if others had the same experience with the smart key and the door handle.
6G TLX-S
What is working ? What alarm is it ? How does it integrate into the factory system ?
Do share your experience.
Funny Guy
Step 1. Buy house with a garage to park $40k car inside.
Step 2. Buy $40k car.
I'm pretty sure that's in the owner's manual, but if not, it should be.
Serious Guy
Are you bypassing any of the factory sensor/alarm to use your aftermarket or just tying into it? I don't think you can disable the keyfob entry or wire around it because part of the immobilizer depends on it or the manual lock being turned on the driver door(AKA, if you didn't unlock the car like busted out a window - you can't start it).
Serious Guy
Wow this forum really turned in the past few years... I don't remember this much negativity towards other members when I was posting in the 3G area.
I installed an aftermarket alarm and starter in my 2012 TL SH-AWD Tech. Everything works the way it is supposed to. I wasn't sure if anyone else had one installed in their vehicle and was curious how theirs behaved during a certain operation.
The operation in a very detailed manner is. You're outside of the car, all the doors are shut and you lock the car with the OEM or alarm remote. Then you walk up to the car with your smart key and touch the inside handle of the drivers door. The drivers door unlocks, but at this moment does the aftermarket alarm disarm? Mine doesn't, and after talking with the engineers at idatalink and xpresskit they've told me it is something they're working on to interface through the databus.
You left out a very valuable info, what kind of alarm did you purchase?
without knowing this, we cant even being to tell you how frustrating is it for us to guess. this thread can go on and on about theories..
for example.
if i asked you to fix my phone that i dropped and cracked. you would ask me what kind of phone is it for you to fix it right?
So your saying you already got your answer, but what another answer to your question??
for example.
for example.
6G TLX-S
BrandonClaps, you also mentioned that your aftermarket alarm system (brand and model still unknown) was integrated into the factory system. Would you also tell us how you do this, so we can get a better understanding of the problem and/or work together for a possible solution ?
Anyhow, the answer to your original question is NO.
No forum member has ever reported that touching the door handle will also disarm his/her aftermarket alarm system.
That's why some members are carrying 2 to 3 remotes around. One for the car, one for the aftermarket alarm, and one for the factory remote starter.
The following 2 users liked this post by Edward'TLS:
BrandonClaps (04-27-2012),
potmilkz (04-27-2012)
I'm using an audiovox prestige 6900 and flashlogic module.
xsilverhawkx
09-28-2015 06:51 PM
