Any decent aftermarket headlamps available?
I'm looking to replace some sun damaged headlamps.
I was able to wet sand and polish the outer plastic, but these have check marks and pits on the INSIDE surface.
I would rather not bake mine to open them up (but I might).
In the mean time...
Are there any aftermarket replacements that are decent? Or are there any aftermarket ones that will accept the stock projectors?
My apprehension with just buying an aftermarket CAPA certified set is that usually, aftermarket ones leak and the projectors are junk.
If there's nothing available, I'll just buy new OEM housings I suppose.
Thanks in advance.
In the mean time...
Thanks in advance.
I installed TYC aftermarket OEM equivalent headlamp assemblies on my son's 2004 Accord; 3 years ago next month.
They seem to be of high quality, they fit great, and no problems so far.
For the 2012 TL, they are a tad pricey but still much less expensive than OEM.
https://www.rockauto.com/en/catalog/...assembly,10762
The inconvenient truth
But...my concern is in the quality of the projector. Fitment is also a concern for me. CAPA certified means they *should* fit.
Was hoping someone had tried them out on a TL.
IMO look for something that can accept the TL-R Bi-xenon projector lamps and mod any aftermarket set you get. Put Clear Bra on the outside and throw a few silica packs in a hidden spot on the inside. You can remove the reflector etc as you please. You might be able to score a set of used OEM ones in good condition on ebay. Make sure you get the dark bezeled ones for facelifted TL.
And yeah, been looking on eBay for 12+ lights and they're either wrecked or they're as much/more than buying new.
For reference, new ones are ~$1200 shipped for both sides. So...not like...expensive.
I could always make up some of it if I sell my set to someone who doesn't mind a little pitting OR someone who wants to take them apart and fix the inside of the lens.
What is the advantage of the bixenon version? Sharper beam or something? I would be keeping the separate reflector brights and using the projector only for low beams. I don't want bixenon brights.
IMO if I had to open up a set of lights I'd get the Bi-Xenon projectors put in. $600/each isn't that bad for OEM!
I just bought a set of OEM lamps from a dealer website that had them listed for way lower than anywhere I've seen.
They confirmed the order...but lets see if they recall it or something crazy happens.
csmeance (04-24-2021)
In the mean time...
Thanks in advance.
In the mean time...
Thanks in advance.
^ Nice!
Mine are pitted on the inside so I wasn't sure it would help.
I bought lights from hondapartsnow or something.
Theyre a Honda parts site so I was surprised they had Acura parts - usually the parts distribution is separated.
Anyway...they cancelled the order the same day lol. Stated the parts were "discontinued". I think they realised how low their pricing was ($450/ea) and that they sold an Acura part.
Anyway, I found an eBay seller selling a new OEM light with 1 broken tab for cheap. I can weld it...so I went for it.
The other light came from a partout at a pretty tantalizingly low price too.
I figure I can sell my lights to someone who wants to open them up. I'm short on time these days.
^ Nice!
echodigital (05-05-2021)
Wow that looks amazing! I was always told to never touch the inside of the headlight. Could you tell me each product you used to achieve this.
I suggest getting a pair of 4TL-r with CBBs You'll have a double HB as well
Microfiber towels like these Polishing paste Menzerna 2500 I use 32oz. because I professionally polish a lot of cars.
For hard-to-reach places, I used ear Q-tips.
If you peel and seal everything correctly without losing the sealant, you will not need a new sealant.
If the original sealant is lost, then you can add a little bit https://www.ebay.com/itm/16433386256...EAAOSwPv9gF8xk
This is how it looks during polishing, I circled the border before and after
Used an electric oven to heat up
Microfiber towels like these https://www.amazon.com/Kirkland-Sign...580&th=1&psc=1
Polishing paste Menzerna 2500 https://www.amazon.com/Menzerna-MCP2...0128023&sr=8-2 I use 32oz. because I professionally polish a lot of cars.
csmeance (05-04-2021)
You are not polishing, you are removing the layer of plaque with a polishing paste. Everything is done by rubbing, the harder you rub in, the faster you will remove this plaque, the microfiber moistened with a paste does not scratch the polycarbonate. I forgot to write the most important thing, completely wrap the headlamp in aluminum foil before putting it in the oven.
Remove the bulb covers, all bulbs, the ignition unit with wire and unscrew the small screws holding the front glass and housings around, completely wrap the headlamp in aluminum foil before putting it in the oven. I baked 20 minutes with 220 F for each headlight. Take it out of the oven, bend all the hinges, gently use a flat screwdriver to pry the corner of the headlight (from the side of the high beam) and use your hands (with gloves) to separate the two halves.
They aren't really that bad, but I want them perfect like yours. Car is dirty pollen is ridiculous
Thank you MR. Altair47 for you help!
3rd Gear
That's the video that first made me aware of them. So I'm afraid that I don't know anything more than what is there nor do I know anyone who's got them. But it is exciting that a company is making the clear side markers again. They were discontinued and almost impossible to get.
