Accord V6/ TL V6....the same?
Old Jul 28, 2009 | 04:10 AM
Melba Toast's Avatar
Question Accord V6/ TL V6....the same?
Accord EX-L V6
3.5-litre, 24-valve, SOHC, i-VTEC® V-6
HP- 271@6200rpm
lb ft torque- 254@5000rpm
TL
3.5-litre, 24-valve SOHC VTEC® V-6
HP - 280@6200rpm
lb ft torque - 254@5000rpm
Why does the TL have 9 more HP?
What is the difference between the i-VTEC and the VTEC?
Why does the TL require premium fuel and the Accord only asks for regular?
Under the bonnets they both look the same beside the different logos and they fact that they TL has a bunch of goofy plastic surrounding it.....
Old Jul 28, 2009 | 07:11 AM
Momyc's Avatar
2015 TLX SH-AWD Elite BWP
Maybe the I-VTEC vs VTEC !??
Old Jul 28, 2009 | 07:19 AM
jmaikamon's Avatar
You pay motre for the i...LOL!
Old Jul 28, 2009 | 02:28 PM
WOW! You guys really hit the nail on the head......
Old Jul 28, 2009 | 04:56 PM
legend74's Avatar
Accord uses regular gas and it also has VCM which may account for some loss.
Old Jul 28, 2009 | 05:30 PM
So technically, you could run a TL on regular? What is VCM?
Old Jul 28, 2009 | 06:34 PM
KeithL's Avatar
Variable Cylinder Managament, it shuts down up to 3 cylinders, Odyssey has had it from some time, my understanding is you have to really be light in the pedal for it to do its thing.
I beleive the TL manual states the TL can use regular for short periods, they got away from defining the specific period, maybe after the gas crunch in the SE last year.
Old Jul 28, 2009 | 06:42 PM
Aman's Avatar
Your Friendly Canadian
IIRC, i-VTEC only uses variable cam timing on the intake, while VTEC has it on both. My guess would be that the power loss comes from a more restricted exhaust and maybe intake in the Accord to limit cabin noise. A shame, if you ask me.
Old Jul 28, 2009 | 06:46 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
I think you have it backwards. IIRC, it's the "intelligen" VTEC that changes timing on both intake/exhaust sides.
Old Jul 28, 2009 | 07:49 PM
Aman's Avatar
is it? I know the K24s have i-VTEC so I always thought the J-series had VTECs.
Wiki says that SOHCs have VTEC on the intake side, i-VTEC has VTEC on the intake cam of DOHCs, but on the K-series, it's got it on both the intake and exhaust? Guess you're right
http://en.wikipedia.org/wiki/I-VTEC
Old Jul 28, 2009 | 08:54 PM
iforyou's Avatar
You'll Never Walk Alone
The engine in the Accord doesn't really have i-VTEC. It's just a marketing gimmick. All it means is that engine has VCM. The "i" stands for intelligent, so by being able to deactivate some cylinders, I guess that's "intelligent"? Temple of VTEC (TOV) tested the Accord V6 and it only puts down around 210whp. The VCM really hurts the performance.
The TL needs premium fuel because of its higher compression ratio. If you use regular fuel, the ECU will retard the ignition timing (and thus less power) to prevent engine knock from happening. In the last generation Accord, it requires regular fuel, but if you put in premium fuel, the engine actually makes more power as shown by a dyno test by TOV.
Old Jul 28, 2009 | 09:08 PM
Well put. Thank you for a decent answer.
Old Jul 28, 2009 | 10:18 PM
Litt's Avatar
This is an interesting press release about noise vibration and harshness. They talk about engineering the TL.
My sales guy said it has triple seals on all the doors, more noise dampening materials, acoustic glass to cut down wind noise.
Granted this release is more about difference betweent the 3G and 4G TLs.
http://www.hondanews.com/categories/733/releases/4677
Old Jul 28, 2009 | 10:28 PM
And this has what to do with the engines?
Old Jul 28, 2009 | 10:33 PM
BLACKURA_NY's Avatar
I have car ADD
well... from what i know (and i could be slightly wrong)
the FWD TL, has VTEC on only the intake, well the 3.7L AWD TL , has VTEC on the Intake and Exhaust...
I dont think I-VTEC only means that you both intake/exhaust... i believe I-VTEC was supposed to be over a broader RPM range, (K Series Engines) to provide a linear power band... VTEC by itself, at least in the Hondas/Acuras i've owned, is a short burst of power, that is more powerful
the new 3.7L Engine is a marvel of Acura (Hondas) new development.... Although the car isnt fast, I am sure this is an amazing advancement for the J Series Engine, and I know CT-E will be making a s/c'er for it...
unfortunately, its still only SOHC
Old Jul 28, 2009 | 11:49 PM
Aman's Avatar
If you check out the Wiki link, it says i-VTEC in the K-series is meant to improve fuel economy in the low revs and increase power in the high revs. So you're right in that it is over a broader rpm range, but the reasons are slightly different.
Old Jul 29, 2009 | 01:45 AM
I have car ADD
my ex-gf had a i4 accord, then a TSX, and ive had RSX & TSX loaners a few times...
My experience, is those cars are obvisouly "slower" because of displacement and what not, but the i-VTEC keeps the car going...
I had a PT cruiser for work, for a few weeks.... 4 cylinder. that thing was terrible.. you floored it, and it moved, but barely.. then sort of died mid-range and higher...
the iVTEC like in the K series engines, i feel kicks in very early (maybe 3.5-4k RPM) and holds true to redline..
Ive had a 3.2L TL, 3.5L TL & 3.7TL... my current gf also has the 3.2 CL-S, and the VTEC is higher rpm usually (4800-5000RPM) and IMO dies just BEFORE redline...
point of that story, is i feel those are the "characteristics" that define the difference between the two, from at least a drivers standpoint...
VTEC - Short lived, very dramatic power increase, high end
iVTEC - spread evenly over a broader RPM range, with less "dramatic" feel and results
Old Jul 30, 2009 | 12:31 AM
iforyou's Avatar
You are welcome Melba Toast
i-VTEC has continously variable valve phasing. In the end, like BLACKURA_NY is saying, it improves torque output at any rpm and there is less "dramatic" feel when VTEC "kicks in."
One of the design goals of the J series is to make a V6 as compact and lightweight as possible. With this in mind, SOHC was chosen. It's still one of the smallest/lightest V6's out there. I also think they have chosen SOHC high peak power isn't the main goal. With that said, it would be sweet to have a DOHC version of the engine for sportier models
Old Jul 30, 2009 | 11:29 AM
prepreludesh's Avatar
Colorado Springs
They do, it's called the C30 and C32, haha
Old Jul 31, 2009 | 01:57 AM
iforyou's Avatar
lol, I meant, something like...J32B...haha
Old Aug 9, 2009 | 01:05 PM
NBPaspec's Avatar
The two main differences are:
1. compression ratio. accord is 10.5:1 and TL is 11.2:1
2. premium vs regular fuel
Old Aug 9, 2009 | 06:52 PM
georgegiorgio's Avatar
G Force
The way I see, they are exactly the same car, not cosmetically speaking, but, seems to me that they both share the same engine, just minor tweak on the Acura side, and then the enterior, the dashboard placement seems to be very much alike, the LCD of the Navigation and tons of buttons...
Even the windows frame shapes looks pretty much alike... Oh, both got lots of chrome everywhere....
Old Aug 9, 2009 | 06:55 PM
Aman's Avatar
well considering that they're both on the same platform, you'd expect there to be some significant similarities.
Old Aug 9, 2009 | 09:27 PM
PsychDoc's Avatar
I feel strongly both ways
Here's some other similarities:
  • They both have four wheels
  • They both come with a steering wheel.
  • The have climate control systems.
  • Gas pedals
  • Brakes
  • An audio system.
There's clearly little question that they are identical.
Old Aug 9, 2009 | 11:06 PM
melrob1's Avatar
Not even close. Traded my 08 V6 Accord Coupe for the 4G TL. Much smoother power. Take off and passing power are night and day. Loved the Accords body style but after i test drove the TL I couldn't even leave the dealership in the Accord. Not sure why must be because of the variable cylinder mgmt on the Accord. I think it really kills the performance.
Old Aug 10, 2009 | 07:33 AM
omnimax's Avatar
My family owns an 03 accord and 09 odyssey and my 09 TL tech is the first premium brand in the family and I all agree that the TL is a major step up.
- The leather and dashboard are softer to the touch, not like the hard plastic on honda cars.
- The car overall feels better put together
- Much better sound insulation
- Probably the best sound system at this price range and my opinion rivals others in higher price ranges, with the possible exception of the genesis
- Much more sporty ride.
- The prestige factor of driving an acura vs. a honda
The list can go on and on but even looking at just features alone, you're getting a more equipped car than a fully pimped out accord. Again all this is subjective but IMO, you're getting a nicer experience and of course, paying for it. The accord is a fine car and can be most things to most ppl. I was looking for a better experience and the TL nailed it.
Old Aug 10, 2009 | 03:37 PM
cornelius's Avatar
The biggest similarity between the 4D Accord and TL are that you have to trick
your mind in a way that makes you believe that it looks good.
emailnatec
29
Sep 28, 2018 04:27 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
Bielikb96
Sep 28, 2015 10:45 AM
