Abnormal engine knock/tick above 3k rpms
Old May 27, 2020 | 02:53 PM
Blackac12's Avatar
2012 Acura TL tech 3.5L 230k miles
I’ve developed a very strange tick or knock(not sure how to describe it.
it comes in around 3k rpms and is very audible at 3500 rpms. Still there at 4K rpms but doesn’t seem as bad as 3500 is.
it’ll do it in neutral or if the car is driving with a load on it.
This is not injector tick
sounds upper engine. the dealer adjusted valves but that didn’t fix it And now they advise to replace the engine. I’ve had the issue for about 2k miles and it doesn’t affect performance or anything other than a cosmetic noise.
I’m going to get a second opinion but wanted to see if anyone on here had a similar issue
video being uploaded as soon as I can figure out how
Old May 27, 2020 | 03:31 PM
Blackac12's Avatar
Video link
Old May 28, 2020 | 10:54 AM
csmeance's Avatar
check the oil for any metal flakes, same with oil filter. Check your spark plugs and make sure they are fully tightened down as the middle cylinders can loosen plugs over time and eject! IT could also be a belt noise but that'll require taking off the accessory belt first or checking the timing belt tensioner. With 230k miles, when is the last time you had your timing belt/water pump service done?
Old May 28, 2020 | 02:09 PM
Blackac12's Avatar
will do. I checked the dip stick and no metal flakes. But will go ahead and change the oil too.
I’ll check the other things you mentioned
timing belt done at 210k with a gated belt and asin kit with all components.
From the research I’ve done it seems like a very uncommon thing and haven’t found anyone with a similar issue.
It sounds a lot worse on video for sure though
Old May 30, 2020 | 07:21 PM
Teddybear's Avatar
Subsonic
Does it tick on idle? Open the hood and listen.
Mine sounded similar, ended up being a bad rear camshaft. Acura ended up replacing that under TSB/Goodwill, because they replaced the front camshaft during the oil consumption piston replacement.
Jeckz
2G RDX Problems & Fixes
Sep 17, 2020 12:13 PM
lidobitesize
5G TLX Problems & Fixes
Sep 12, 2017 03:45 PM
aIRpeACE
Jan 14, 2016 03:54 PM
miked8887
Oct 2, 2008 01:30 PM
6speedctrlfreak
Apr 14, 2003 11:37 AM
