2012 Fog Light - Full replacement
My passenger side fog light was shattered (see pics). Not that I would have them do it, but the Acura dealer wanted $440 to replace it. Balking at that and without asking, I assume that they are wanting to replace the entire molding with the reflector lights?
Before I go buying new fog lights, is it pretty straight forward in swapping them out? Undo around 4 or 5 bolts on the bottom cover below everything or is it in more detail than that? Any help would be appreciated as I checked for videos on replacing them with no luck.
Cheap bulbs -> Passenger Driver Fog Light For ACURA ILX 13-15 RDX 10-15 TL 12-14 TSX 11-14 Black - Mad Hornets
Actually, found this. But will this replace the lens as well?
https://www.carcarekiosk.com/video/2...lights/foglamp
https://www.theretrofitsource.com/ac...to-xb-led.html
Two high quality full LED assemblies for half the price
This is the part from acura, just the foglight glass/bowl itself without the extra bits:
https://www.acuraoemparts.com/v-2013...fuel--foglight
It's $140 plus shipping, use coupon code acurazine to save 5%
If the XB LED's are cheaper, try those out! However you may have a harder time seeing in fog since the light they emit is white and fog lights tend to be yellow to increase contrast.
I used these and they they were a perfect fit. $34
https://www.walmart.com/ip/iJDMTOY-A...&wl13=&veh=sem
Thanks for the link from Walmart. Actually went with these which are most likely the same thing. I plan on putting them in today.
Didn't have the balls to justify spending $150 on fog lights... even though the LED's are pretty slick. I already dropped over $2k out of the gate on timing belt and alternator.
https://www.ebay.com/itm/For-2012-20...53.m2749.l2649
