2012 Acura TL trunk/cargo light
Hi All
My trunk light is gone and I can't figure out whats wrong with it. I have already checked all possible fuses and according to manual there seems no switch anymore as my old TL had. Anyone have any ideas suggestions would be really appriciated!
Mark
Mark
I actually just resolved a problem. While putting the factory bulb back I pulled out entire light fixture. I noticed that the plastic fixture have little resistor between the feed. So I used little wire to by pass the resistor and voila light is working again.
I think the resistor is the to lower the power consumption because the light is on all the the time (newer models don't have trunk switch anymore). So am thinking that just having my led there is enough since it uses less power than original one anyway and I don't need to replace the resistor.
My trunk light died and changing to a new bulb didn't do anything. I took it the dealer and they couldn't diagnose why. They will change driver side fuse box panel as to see if that will fix the problem. Hope that'll fix it.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
BobbyGraham388
Oct 22, 2015 05:05 PM
Nitin
Sep 30, 2015 08:22 PM
