2010 TL left side mirror
Hi guys, I need to replace my left side mirror on my 2010tl. Some idiot swiped my car and cracked it when it was parked. I went on eBay and found some which was used with minor scratches. It says 2009-2014. My question is are all the years within this generation the same. I hate to buy one if it looks different then my right side mirror even though it fits. I'm looking for pearl white. If you know anywhere cheap in queens New York or online please let me know. Thank you
The part no you need is 76250-TK4-A01ZC which is $276 on acuraoemparts.com & you can use acurazine as a coupon code for 5% off.
You can also find a used mirror online though salvage yards or ebay. I like to use car-part.com for my searches. Also you can buy just the prepainted shell rather than the whole mirror for around $50 from the same site:
MIRROR for 2009 Acura TL
The 2009-2011 mirror is slightly different than the 2012-2014 TL mirrors in white, probably due to the new shade of white in 2012+ models.
So from the looks of it, I just need the housing set and the heated mirror itself right?
Hi,
Did you complete the repair? Was it relatively easy? Are there instructions anywhere? Did you need any parts beyond the housing set and mirror?
I'm in a similar situation (except in this case I'm the idiot - hit the side of the garage backing out). ONLY the front part of the mirror unit is damaged - not the turn signal, not the mirror itself, not the back plastic piece, etc. Only the housing set, based on the parts diagram.
Thanks for any tips!
Marc
Marc
