2010 TL 6-6: Rear spring removal?
Hey all, just got the H&R springs and was wondering if anyone knows how to remove the rear springs? I don't really want to start tearing up the trunk if that is not the way. I have installed suspensions before on older honda/acuras, but I'm new to the new.
If anyone has a diagram, that would work too. Thanks for any help!!
-DeL
-DeL
the garages around my area are charging $250-400 for removal and install for all four! I was like BS!
If anyone can provide the diagram or manual for the rear, I can do a DIY on this, as I have done this many times, just need the rear before I start it. Thanks!
-DeL
-DeL
I know its not much but if you check this thread on a FWD he talks about removing the back seats.
https://acurazine.com/forums/4g-tl-tires-wheels-suspension-298/project-tl-4-test-fit-769174/
https://acurazine.com/forums/showthread.php?t=769174
^^ Yup. You've gotta remove the rear seats to get the springs installed. Mine was for AWD. Didn't even bother to install them myself, it wasn't worth it to kill a day installing them when I could be working instead.
I have car ADD
FYI- you should just take the seats out, and then bring it a shop. they will charge alot less labor if they dont have to figure out the seats (because every car is slightly different)
2 Clips, 4 Bolts. Seats come right out
Also, as a rule of thumb, mechanics have dirty hands. you dont want them touching your interior, unless you know them and they are going to take special care/attention not to get greasy, dirty handprints all over your rear deck and c-pillar
-DeL
cycdaniel
12-17-2019 10:58 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
